ᐅ Obtain the correct rubber gasket for the toilet outlet bend.
Created on: 26 Apr 2021 17:14
Gerd53
Gerd53
26 Apr 2021 17:14
Measured with a ruler, the connection pipe of the floor-mounted toilet is 12.5 cm (5 inches).
An online hardware store offers a rubber sleeve for the toilet connection bend with an outer diameter of 13 cm (5 inches). Since the drain pipes are likely standardized, I assume that the 13 cm (5 inches) size is correct and that my 12.5 cm (5 inches) measurement may have some error.
The inner diameter is not specified.
However, there is a note:
"This white rubber sleeve with a diameter of 130 mm can be used to replace the seal on all common drain pipes."
The toilet drain, measured with a ruler, is 9.7 cm (4 inches) in my case.
The current rubber sleeve has a height of approximately 1 cm (0.4 inches).
The new one from the hardware store is 2 cm (0.8 inches).
Is the offered sleeve suitable for my floor-mounted toilet?
Thank you
