ᐅ Number of recessed ceiling lights in the upper floor hallway
Created on: 11 Feb 2020 23:55
Andre77
Hey,
Currently, three recessed spotlights are planned. However, I’m not sure if three are too few, meaning it might be too dark.
As shown in the pictures, these will be installed. Are the performance specifications sufficient?
And in the bathroom, simply arranged in a row, also three units.
Thanks for your feedback!
Verpackung eines runden LED-Spotlights von Lumare, 360 lm, 6W, dimmbar 3000K, IP44.
Verpackung einer 6W LED-Spotlampe, 360 lm, Ø115 mm, Tiefe 26 mm, Diagramm.
Grundriss eines Gebäudeteils mit Treppen und Wänden; drei rote X markieren Flächen.
Grundriss eines Badezimmers im Kellergeschoss mit drei roten X-Markierungen
Stefan890
12 Feb 2020 22:25
You can also plan your spotlights with DIALux evo. It is a free lighting design software.
NatureSys
12 Feb 2020 22:26
They are the same. In the hallway, the light appears warmer only due to the reflection from the books and the parquet flooring. Each has 800 lm, 3000 K, and a lens diameter of 60 mm (2.4 inches).
12 Feb 2020 22:27
Lighting should be planned individually for each room. The rule,
NatureSys schrieb:
The optimal position for spotlights is not in the center of the room, but on the side.
was not applied in your hallway either. There, the style of the lamp might take precedence, placed centrally in alignment. The highlights in front of your furniture are practical.
@Andre77
I would place a modern spotlight at the intersection of the two axes in the hallway. Surface-mounted. Centered. With two fixtures. For example, like the ones @NatureSys has in their hallway. You can still add a floor lamp near a power outlet under the sloped ceiling.
Andre77
12 Feb 2020 22:27
Stefan890 schrieb:
You can also plan your spotlights with DIALux evo. It is free lighting design software.
Thanks for the tip, but unfortunately it only supports Windows...
Andre77
12 Feb 2020 22:45
@ypg
Oh, I’m kind of stuck on the recessed lights right now... as a change from the current 4-bulb round/spiral fixture.
In the bathroom, around 1000 lumens per spotlight should be fine, right? Should they be warm white, cool white, or neutral white?
By the way, which spotlights would you recommend for the eaves?
NatureSys
12 Feb 2020 22:47
The 3000K lighting in our bathroom works perfectly for us.
