ᐅ Number of network outlets; how to plan Wi-Fi in a new build?
Created on: 22 Aug 2019 10:27
Pamiko
we need to decide soon on the number of network outlets required throughout the house.
Basically, we agree on where to place outlets (living room, office, children's rooms, bedroom...) for connecting stationary devices.
However, I am a bit unsure about what exactly needs to be planned to ensure good Wi-Fi coverage on both floors.
What I find online about this topic is beyond my current understanding.
Would it be possible to simply install one network outlet centrally on each floor and connect a device there to extend the signal? What kind of device would that be?
(I have often read about access points.)
Looking forward to some beginner-friendly advice. Thank you very much.
M4rvin4 Sep 2019 18:32
Most of it has already been said...
Place an access point on the ceiling in every hallway (Light or Pro, depending on how much you want to spend).
With UniFi, the PoE injectors are included, so using a PoE switch doesn’t really make sense.
200/400 Mbps is quite impressive; I think for us it would have been around 100/150 Mbps.
But we have an access point in every room anyway, and instead of the satellite socket, we got a network outlet as a cost-neutral replacement. So, apart from exceptions, we only have two individual outlets per room. If there’s a real need, you just plug in a small switch at the outlet. The main thing is to keep the location flexible, and at least you have one connection for the TV and one for the PC.
guckuck2
4 Sep 2019 19:25
Scout schrieb:
Um, a duplex cable IS two 8-wire network cables, just glued together....
Exactly. And he should leave it at that. Pulling duplex cables is a real pain.
ti-mar90
4 Sep 2019 19:29
guckuck2 schrieb:
Exactly. And it should stay that way. Pulling duplex cable is a pain.
Better to run 2 simplex cables through a conduit???
guckuck2
4 Sep 2019 19:36
ti-mar90 schrieb:
Better to run 2 simplex cables through one conduit???
Definitely.
apokolok
4 Sep 2019 21:00
Yes, that’s what I meant.
rick20185 Sep 2019 07:17
Access points should not be placed in the hallway area but rather where the highest speed is needed.
