Since my maximum installation height is unfortunately very limited (max. 50mm (2 inches)), I have to use a thin-layer screed system. Schlüter offers a suitable system with Bekotec. It provides the option to choose an installation spacing of either 75mm (3 inches) or 150mm (6 inches).
What pipe length per m² can be expected with these spacings? Unfortunately, I only find information online for 100mm (4 inches) or more: for 150mm (6 inches) spacing, it would be around 5.8m/m² (Schlüter’s own calculator indicates approximately 6.7m/m² -> which one is correct?). How much pipe length per square meter would it be with a spacing of 75mm (3 inches)?
For example, with my roughly 35m² (375 ft²) living room, this would already result in 6 separate heating circuits if I want to keep each circuit under 100m (330 ft).
How should I decide which spacing to choose, and would 15cm (6 inches) spacing be sufficient?
X
xMisterDx23 Dec 2023 18:11How does the compressive strength hold up when, in the end, there is more pipe than floor surface to cover?
jens.knoedel23 Dec 2023 20:45xMisterDx schrieb:
What about compressive strength, especially when there’s more pipe than floor surface to cover in the end?That’s exactly why there is a minimum pipe coverage requirement, ensuring you have a continuous minimum screed thickness — which usually also matches the minimum thickness for floors without underfloor heating. Therefore, the pipe spacing is irrelevant.X
xMisterDx24 Dec 2023 11:32That doesn’t make sense. What happens with a joint spacing of 0? The screed layer, no matter how thick, is not self-supporting like a concrete slab. It is supported from below... Well, it will probably be fine anyway 😉
WilderSueden24 Dec 2023 13:54In reality, no one installs with a spacing of 0cm. At 7.5cm (3 inches), there would still be about 85% screed coverage, which is not an issue with appropriate overlay.
