Yesterday, we discussed the ventilation plan for the mechanical ventilation system on the construction site. The ducts are planned to be installed in the floor structure on the first floor and then drilled downward. On the first floor, the supply air should ideally be delivered through floor outlets in front of the windows to save usable space. However, we decided to install the outlets about 30cm (12 inches) higher on the wall. Although this means an additional 90-degree bend in the ductwork—which I understand should generally be avoided—the advantage is that no dirt or liquids can enter the opening.
Now to the main question.
In the living room, two air outlets were initially planned. Since we wanted to move one of them (above the coffee table), the suggestion came up to use only one outlet instead. The size will be properly calculated by the HVAC installer.
Are there any advantages or disadvantages to this? I read that the noise level might be higher with a single outlet. However, the general contractor said a larger duct would be installed accordingly.
For now, I am convinced by this explanation. The general contractor noticed that I felt the decision was made a bit too quickly and offered to install two outlets if desired. We are planning to start with one large outlet, and I have until the end of next week to decide.
My wife sees the advantage that a single outlet is less noticeable, and only one hole needs to be drilled through the ceiling.
The living room is approximately 34m2 (366 square feet).
Fanta
Fanta
Polle 196725 Feb 2015 16:20Hello
We also have our ventilation outlets on the ceiling. In the living-dining room of the same square meters, we also have 2 units.
Otherwise, as Dr Schnaggels already mentioned.
If you have a fireplace, don’t forget to plan a separate air supply for it, otherwise you might have problems with the chimney sweep.
Regards
Regards
