ᐅ Novelan Heat Pump Error 704 – Hot Gas Fault
Created on: 17 Dec 2022 08:47
chewbacca123
our heat pump just displayed an error message: high gas fault, error code 704. We have a heat pump from the brand Novelan. What should we do?
Would you call an emergency service immediately? I’m feeling a bit overwhelmed right now. It is -11°C (12°F) outside.
Thank you very much and best regards
Anzeige zeigt Heissgasstörung 704, Reset in 1:58:22, Knopf mit grünem Lichtring.
SoL
17 Dec 2022 10:40
Can you switch to heating only?
If the low temperature setting works, at least you'll have heating. Hot water can be improvised until the technician arrives.
chewbacca12317 Dec 2022 10:47
If low temperature mode works, at least you have heating. Hot water can be improvised until the technician arrives.
Yes, that seems possible…
But I’m worried that the compressor might break down now.
KingJulien17 Dec 2022 10:56
Do you have no emergency operation, solely relying on the electric heating element?
chewbacca12317 Dec 2022 12:23
KingJulien schrieb:
Don’t you have an emergency operation, running solely on the electric heating element?
We have a second heat source, and the heating is working. I have turned off the hot water for now and have to wait until a professional arrives.
Daniel-Sp
29 Dec 2022 07:31
Hello @chewbacca123,
I just saw your post now.
I hope you and your family still had a nice Christmas.
What is the current status? Hopefully, you have switched the hot water preparation to an electric heating element?
The last data logs from your LAD did not show any irregularities regarding hot gas during hot water preparation, but they are already a bit old. Do you have logs from just before the error message appeared?
Regards
chewbacca12329 Dec 2022 07:36
Daniel-Sp schrieb:
Hi @chewbacca123,
What’s the current situation? Hopefully, you have switched the hot water preparation to the electric heating element?
The last data logs from your heat pump controller didn’t show any issues regarding the hot gas during hot water preparation, but those logs are already a bit old. Do you have logs from just before the error message appeared?
Good morning, yes, Christmas was great. I hope you’re all doing well and had a nice holiday too.
Unfortunately, I don’t have any recent logs. We are currently on a ski vacation, so things were quite tight and stressful just before Christmas.
The error has not occurred again. I agreed with our heating technician that if it happens again, a specialist company will be called in. Our plumbing company cannot do anything about error 704.
Since then, the heat pump has been running perfectly. The error definitely occurred when it was -11°C (12°F) outside. It probably had something to do with the location, but it wasn’t a normal situation. Fortunately, we have a secondary heating source that we could switch to if needed.
