toxicmolotof24 Jan 2018 07:54Our plumber simply laid the two supply lines to the children's rooms, which run through the hallway, in two generous loops (about 4m² (43ft²)) within the hallway instead of taking the direct route. When you heat the children's rooms normally, the hallway also gets slightly warmed. This seemed like a practical solution without much complexity, additional electrical work, or fuss. For a larger playroom hallway or library hallway, I might consider a different approach.
Knallkörper24 Jan 2018 08:00Upstairs, we have the heating on almost only in the bathroom. There is a separate loop in the upstairs hallway, but it does not have its own room temperature regulator; instead, it is controlled together with the bathroom. This has proven to be the best solution for us.
