ᐅ New Single-Family Home Construction – Join Us on Our Journey!
Created on: 4 Aug 2022 16:13
gregman22
Dear community,
We are finally getting a step closer to realizing our dream of building a single-family home.
The plot has been purchased, building plans have been reviewed, construction method decided, and so on. We have now commissioned the architect of the general contractor (GC) of our choice with the planning task and are currently fine-tuning the house design. I would love to take you along on this journey and incorporate your valuable feedback.
At this stage, the focus is on the house design.
Basic data:
Plot: 1062m2 (11,433 sq ft); approx. 25.5m x 41.64m (84 ft x 137 ft)
Orientation: Northwest -> The arrow in the screenshot of the 3D view points south
Desired room layout:
Ground floor:
First floor:
Attic:
Note: I am still discussing this with the architect. Due to the hipped roof shape, the actual living area has shrunk too much. Therefore, further discussion is needed to accommodate the other rooms. I had underestimated the ratio of gross floor area to usable living space.
Basement:
Additional plans:
Now to my first questions for you:
My biggest construction challenge at the moment is the layout of the attic. There are two alternatives:
- Change the roof type, which would increase costs but provide more usable living space in the attic
- Give up the playroom on the first floor, convert it into a guest room, and build only the two offices in the attic (no guest room or bathroom)
Thank you in advance for your comments.
Basic data:
Ground floor:
- Large living/dining area with adjacent (but separable) kitchen at the bottom left, plus a gallery overlooking the first floor
- Utility room
- Guest toilet
- Garage
- Separate apartment at the top right with its own entrance for parents-in-law
First floor:
- Gallery overlooking the ground floor
- 2 children’s bedrooms with a shared bathroom
- 1 playroom (initially a home cinema room, later to be repurposed) above the garage
- Master wing with main bedroom, dressing room, and bathroom
Attic:
- 2 separate offices
- 1 guest bedroom
- 1 small guest bathroom
Basement:
- 1 technical room
- 1 laundry room
- 1 storage room
- Large fitness room
- Wellness room with sauna
Additional plans:
- Air-to-air heat pump or air-to-water heat pump
- Photovoltaic system with/without battery storage
- Possible pool (3.5/4m x 8m or 3.5/4m x 12m) with heat pump (and countercurrent system)
- Sauna in the basement room
- Air conditioning for various rooms
- Smart home system – most likely via KNX
- Garden: Currently planning 2 terraces – one to the left, slightly more to the south, and one facing the main part of the plot further north
- How do the floor plans strike you? Do they make sense in terms of the dynamics of family life?
- The location of the separate apartment was chosen based on our wish. We wanted a strict, clearly defined spatial separation with a separate entrance. Do you have any comments on this?
- Do you consider the utility rooms in the basement to be adequately sized (considering KNX, heat pump, etc.)?
Myrna_Loy6 Aug 2022 20:56Neubau2022 schrieb:
I read 9 m x 3.75 m (29.5 ft x 12.3 ft) pool... We are not at @rick2018 here 😎 Thank you, I had overlooked the decimal point.
soneva20126 Aug 2022 20:58Neubau2022 schrieb:
I am reading 9 m x 3.75 m (30 ft x 12 ft) pool... We are not on @rick2018's level here 😎Exactly. I have the same taste as Rick but unfortunately not his budget!
gregman227 Aug 2022 08:32Good morning everyone,
First of all, I want to thank you for all your suggestions and justified criticisms. Even if you didn’t always feel that I was doing what seemed right in our situation, I have taken every single comment to heart.
After long family discussions and considerations, I have now decided to take a step back:
Starting fresh! Here we go!
- Cancel the general contractor’s planning contract within the 2-week cancellation period. We had agreed on an “immediate start of work” clause, so I will probably have to pay a penalty for the few hours worked – that’s part of the learning process!
- Prepare our requirements again properly, without too many specifications, for the architect
- Commission the planning firm we have already selected from several options
k-man20217 Aug 2022 08:52I think that’s great! It takes courage to make a decision like that, but you probably wouldn’t have been happy with the messed-up old plan!
fromthisplace7 Aug 2022 09:03Good!
Plan a bit smaller, but a bit better.
gregman227 Aug 2022 09:04k-man2021 schrieb:
I think that’s great! It takes courage to make a decision like that, but you probably wouldn’t have been happy with the messed-up old plan! Absolutely. And I have to hold myself accountable here. I was too caught up in a "dream scenario" and just didn’t want to accept that with such a high budget for us, there simply wasn’t more to be had. However, the wrong approach truly is to recklessly look for cheaper solutions. It’s like searching for a doctor who will declare you healthy despite obvious illness 🙂
