ᐅ New Single-Family Home Construction – Join Us on Our Journey!
Created on: 4 Aug 2022 16:13
gregman22
Dear community,
We are finally getting a step closer to realizing our dream of building a single-family home.
The plot has been purchased, building plans have been reviewed, construction method decided, and so on. We have now commissioned the architect of the general contractor (GC) of our choice with the planning task and are currently fine-tuning the house design. I would love to take you along on this journey and incorporate your valuable feedback.
At this stage, the focus is on the house design.
Basic data:
Plot: 1062m2 (11,433 sq ft); approx. 25.5m x 41.64m (84 ft x 137 ft)
Orientation: Northwest -> The arrow in the screenshot of the 3D view points south
Desired room layout:
Ground floor:
First floor:
Attic:
Note: I am still discussing this with the architect. Due to the hipped roof shape, the actual living area has shrunk too much. Therefore, further discussion is needed to accommodate the other rooms. I had underestimated the ratio of gross floor area to usable living space.
Basement:
Additional plans:
Now to my first questions for you:
My biggest construction challenge at the moment is the layout of the attic. There are two alternatives:
- Change the roof type, which would increase costs but provide more usable living space in the attic
- Give up the playroom on the first floor, convert it into a guest room, and build only the two offices in the attic (no guest room or bathroom)
Thank you in advance for your comments.
Basic data:
Ground floor:
- Large living/dining area with adjacent (but separable) kitchen at the bottom left, plus a gallery overlooking the first floor
- Utility room
- Guest toilet
- Garage
- Separate apartment at the top right with its own entrance for parents-in-law
First floor:
- Gallery overlooking the ground floor
- 2 children’s bedrooms with a shared bathroom
- 1 playroom (initially a home cinema room, later to be repurposed) above the garage
- Master wing with main bedroom, dressing room, and bathroom
Attic:
- 2 separate offices
- 1 guest bedroom
- 1 small guest bathroom
Basement:
- 1 technical room
- 1 laundry room
- 1 storage room
- Large fitness room
- Wellness room with sauna
Additional plans:
- Air-to-air heat pump or air-to-water heat pump
- Photovoltaic system with/without battery storage
- Possible pool (3.5/4m x 8m or 3.5/4m x 12m) with heat pump (and countercurrent system)
- Sauna in the basement room
- Air conditioning for various rooms
- Smart home system – most likely via KNX
- Garden: Currently planning 2 terraces – one to the left, slightly more to the south, and one facing the main part of the plot further north
- How do the floor plans strike you? Do they make sense in terms of the dynamics of family life?
- The location of the separate apartment was chosen based on our wish. We wanted a strict, clearly defined spatial separation with a separate entrance. Do you have any comments on this?
- Do you consider the utility rooms in the basement to be adequately sized (considering KNX, heat pump, etc.)?
Myrna_Loy5 Aug 2022 20:55Tassimat schrieb:
I consider the original poster diplomatic enough not to come across as aggressive and to politely ask for some information. In my building services office, there are also different people involved than just the application processors.
I personally experienced how the city official was nice to me, while the architect sitting next to me was constantly being scolded for not knowing this or that, even though she was an architect and should have done more, etc. It was only about the preliminary question of how much I could enlarge the dormers. I wanted them bigger than all the neighboring buildings. Later, I went back alone with new plans, and it went very smoothly in my favor. However, the original poster wants to significantly exceed the floor area ratio and the building envelope. That is different from just enlarging a dormer.
Myrna_Loy schrieb:
But the original poster wants to significantly exceed the floor area ratio and the building envelope. That’s different from just having a larger dormer. Of course that's different, but you can still ask about it quite straightforwardly in a personal conversation. Especially since some neighbors have done the same, right?
gregman22 schrieb:
That’s why the current strategy is to adjust the building envelope through an approval process (although to a lesser extent than some neighbors). As I said, this isn’t an official preliminary building request but a general advisory discussion. From my experience: I had some ideas, went to an open consultation without an appointment (even before the meeting with the architect), and they reviewed the neighboring development hands-on using Google Earth, checked if there was a zoning plan, and gave a non-binding indication of whether it’s worth continuing with this planning. Nothing more was intended. In my case with dormers, the answer was “maybe,” because eventually that floor would have counted as a full story. Later, it turned out the ceiling height in the hallway wasn’t sufficient, so I was allowed to build two very large dormers with standard ceiling heights in the pitched roof 😀
Back to this case: It’s suggested that neighbors were allowed to build more, so the original poster has to find out if that’s possible for them too. Perhaps the mentioned neighbors fall under a different zoning plan or something else… this can be clarified quickly and easily.
Additional note about the building service: In my city, there is always a firefighter present who immediately notices that the original poster’s attic, as planned, does not have a valid second emergency escape route (in North Rhine-Westphalia). The dormers are set too far back (>1 meter (3 feet)), so an extremely ugly roof ladder step has to be installed to allow access by ladder.
gregman225 Aug 2022 21:21Thank you for the many comments this evening! I will go through them tomorrow.
Maybe a brief background on why I decided to lean towards a general contractor.
At first, I was also talking to architects and had already chosen a preferred design firm. However, to be honest, from my perspective, the budget didn’t stretch far enough for us. All the architects were on a similar level. For a 1.65m (5 ft 5 in) building, they planned 300m2 (3,229 sq ft) of living space (including a separate apartment) without adding a number of extra costs: no kitchen, no furnishings, no pool, no sauna, no special architectural requests planned so far, and so on. Plus – no price guarantee, since it was only architectural planning. Honestly, when I added up my assumptions for additional costs, I would have ended up between 2.0 and 2.2 million – WAY too high.
That really discouraged me, and I started comparing with initial offers from general contractors. I was very aware of the tradeoff, but at least I found their price estimates more conceivable...
And honestly – to get a first cost estimate without detailed planning and extras at 1.65 million for 300m2 (3,229 sq ft) feels simply too high. Three architects roughly agreed on that.
Working backward, that would have meant reducing the total space to around 250m2 (2,691 sq ft) including the separate apartment, and with that budget many of our room preferences would have been lost.
Can you relate to this, or was I on the wrong track?
Myrna_Loy schrieb:
Regarding the construction budget, I would rather consider building an underground garage instead of using the space above. The area for the garage would be calculated separately anyway.
Sunshine387 schrieb:
It’s nice to see you are open to a somewhat different layout. I don’t think he is open to such an orientation (NE)... and I wouldn’t be either, by the way.
gregman22 schrieb:
Can you relate to this, or was I completely off track? Wrong. I’ve already said that it is negligent. A general contractor is cheaper because, for logistical reasons, they simply can’t handle certain specific tasks. But I don’t want to repeat myself here: you seem to consider yourself capable of making your own decisions.
Myrna_Loy5 Aug 2022 21:32ypg schrieb:
The space for the garage was calculated separately.Sure, but why should cars get a nice, level 35 sqm (375 sq ft) area? I would rather put them in the basement.gregman22 schrieb:
Can you relate to that, or was I off track?Well, if several experienced architects gave you the same result, I would be suspicious if a general contractor promises to meet all your wishes. Does it really have to be such a massive structure? Bigger doesn’t always mean better.
