ᐅ New Construction Flat Roof Waterproofing: Structure and Exposed Seams in EPDM Membrane
Created on: 23 Sep 2019 20:48
Der_Anbauer
Der_Anbauer
23 Sep 2019 20:48
Our extension has progressed quite a bit by now, and everything has gone very smoothly so far. However, I have some concerns about the installation and execution of the flat roof waterproofing. I would be interested in your opinions on the following two questions:
1.: Construction of the flat roof waterproofing in the extension (cuboid) above the first floor, from bottom to top:
  • Precast concrete slab, reinforced according to structural calculations and cast with concrete
  • A brick parapet wall (2 courses of bricks) on three outer sides of the concrete slab
  • Primer for bitumen roofing membranes
  • Bitumen roofing membranes (MOGAT Bärenhaut V60 AI S4) -> Intended as vapor barrier and second waterproofing layer
  • Unilin Utherm LE 50mm (2 inches) PIR rigid foam insulation boards -> insulation layer
  • Sloped insulation made of EPS (expanded polystyrene) with about 2% slope
  • 20mm (3/4 inch) tongue-and-groove OSB boards directly installed on top of the EPS boards (for load distribution since the flat roof will be used as a roof terrace)
  • RESITRIX EPDM membrane for waterproofing
Does this build-up seem reasonable to you? Could there be any moisture issues with the OSB boards (assuming the EPDM membrane is watertight)?
2.: Installation of the EPDM waterproofing membranes
I was up on the roof today to take a closer look at the seams. Almost everywhere the EPDM membranes appear to be tightly welded together at the edges. However, in some places the seams are not properly sealed; in some spots, in my opinion, they don’t seem to be welded together correctly at all. Does anyone have experience with how this should be done correctly and whether I should be worried? I will talk to the roofing contractor and the site manager tomorrow and possibly have an independent third party inspect it. What would you recommend? Please refer to the photos for evaluation.
Thank you very much for your support!!!
Der_Anbauer
Close-up of a dark fabric with a torn seam and dust particles.
Close-up of a black membrane with a seam and a small hole; dusty.
Close-up of a black membrane with a seam and dust particles.
Close-up of a rain-wet roof edge with puddle of water between dark metal panels.
Dark interior of a grill with soot; a metal grill grate rests at an angle on a blue base.
Flat roof with black covering, puddles; red tiled roof in the background, rural fields.
Close-up of black membrane with seam, dust and small particles.
Wet asphalt surface with puddle on the left, dark stains and shoe prints on the right.
Roof surface with red clay tiles at the top edge and black bitumen membrane below; dust.
Close-up of dark fabric floor with seam and dust particles.
X
xray107
24 Sep 2019 20:13
Hi!
What came out of your conversation today with the roofer or site manager?
I’m not an expert in roof waterproofing, but this doesn’t seem correct to me.
Try searching for this:
Simply explained: the RESITRIX® seam welding with the hand welding tool
Watch the first video! From about 1:30 minutes it says that “a very clearly visible bitumen bead of 2 to 4 mm (0.08 to 0.16 inches) must appear.”
I don’t see that consistently here. On the RESITRIX website under Service, you can find more videos.
If in doubt, besides an expert inspector, you could also ask the membrane manufacturer for their opinion. They usually have application specialists on staff. The manufacturer’s reputation is at stake, and they definitely have an interest in proper installation.
Regards
xray
tamtamtam
26 Sep 2019 10:16
My first welded seams looked just like that when I tried working on our garden shed about 10 years ago.
I would definitely hit him with that.
apokolok
26 Sep 2019 12:24
From the looks of it, the sheets are not welded but glued. As far as I know, this is also the current standard practice for EPDM membranes. The adhesive bonding covers a larger area than welding. Whether the seams are actually watertight cannot be determined like this, in my opinion. I used this type of membrane to cover the flat roof of a shed, and it also looked somewhat rough in places. However, that was my very first time doing it, and it’s just a shed... In other words, talk to the roofer and site manager about it again, document everything, and ideally get them to sign something confirming that you have pointed out to them that, at least from your perspective, the work does not seem properly done and may be leaking. https://www.hausbau-forum.de/attachments/img_4223-jpg.38376/ What worries me most is that it looks to me as if the joint runs through the entire adhesive layer.
Der_Anbauer
27 Sep 2019 10:18
thank you for your assessments. A good solution has now been found:
I contacted the manufacturer of the EPDM membrane and sent the regional field representative the link to the pictures. At the same time, the site managers and the roofing company (who had subcontracted the sheet metal workers again...) immediately agreed that rework was necessary. As a result, a meeting took place yesterday morning with all parties involved and the EPDM manufacturer’s field representative (now that’s really good service). The specialist’s assessment: The roof is poorly done.
Suggested solution: A new, single-piece EPDM membrane of about 6 x 6 meters (20 x 20 feet) will be installed on the roof. This will be custom-made by the manufacturer and will have no manually welded seams anymore. The membrane will then be folded up on the inside of the parapet using a folding technique. The EPDM company, which produces Resitrix, will be present throughout the entire installation and will conduct on-site training for the sheet metal workers and roofing company on this product. Essentially, our roof will serve as a reference project. I’m excited—I won’t have to worry about this anymore.
Der_Anbauer
apokolok
27 Sep 2019 11:30
Wow, that’s a great solution!
