Our heating system was put into operation three weeks ago. Unfortunately, the roofers installed these black things (I don’t know the name, see photo Roof 2) in between. Because of this, a lot of moisture has accumulated, and now the beams are starting to develop mold.
Our construction manager said we should wait until everything dries out first and then treat the roof beams. In the long term, we don’t expect any negative effects.
What do you think about this?
Thanks and best regards
LG
LG
TitusPullo7 Jan 2021 22:08Thanks, that clears up the mystery 🙂
Nida35a schrieb:
They should definitely be installed by the time water droplets regularly form on the underlay membrane.What could cause water droplets to regularly form on the underlay membrane? With a cold roof, this should never happen or be allowed to happen...
In the case of an unventilated roof (cold roof), there is a construction defect or a leak in the thermal envelope (it could be the attic ladder, penetrations, or similar).
If more warm air rises from below than is ventilated out at the top, the underlay membrane becomes damp or wet.
We check the underlay membrane every time we go up there;
for us, everything is dry, and there is always a noticeable airflow.
TitusPullo15 Jan 2021 00:01I don’t think this is a problem anymore; the water droplets are gradually decreasing. The question is what to do about the roof beams—will it be sufficient to treat them?
