ᐅ New Construction: Insulation of Collar Beam Ceiling and/or Roof?
Created on: 30 May 2016 19:50
kassiopeiaK
kassiopeia30 May 2016 19:50We are currently planning the new construction of a single-family house with a pitched roof. The attic will be used as the location for a gas condensing boiler as well as for storage. Access will be via a pull-down staircase.
Where would insulation be ideally placed?
Thanks to everyone.
- Only the roof (disadvantage: you also heat the attic in winter and the upper floor may get somewhat warmer in summer)
- Only the collar beam ceiling (disadvantage: no frost protection for the heating system)
- Both (disadvantage: cost)
Thanks to everyone.
Bauexperte30 May 2016 22:13The question does not arise; the heat generator must be located within the insulated building envelope.
Curly schrieb:
Don’t you get problems with mold if the roof is insulated but not ventilated? In new buildings, there is usually a mechanical ventilation system that can handle this. Maybe it is even installed up there?
