ᐅ New Construction and Heavy Rain Affecting Foundations
Created on: 9 Oct 2019 09:15
buzzi_cement
buzzi_cement
9 Oct 2019 09:15
Our shell construction is gradually taking shape, and the exterior walls as well as some interior walls of the ground floor are already standing. Construction started on October 24, 2019. Unfortunately, it has been raining every day since then, and I am concerned about the moisture.
Do you have any advice on how to handle this situation?
Thank you very much and best regards
apokolok
9 Oct 2019 09:19
Yes, relax. It will dry again.
U
User0815
9 Oct 2019 09:24
Use a dehumidifier if necessary as soon as the house is weather-tight.
mini_g!
9 Oct 2019 10:33
I wouldn’t take that for granted right away. For example, the open wall crowns could be covered.
I believe I remember that depending on the type of bricks, this is sometimes even specified by the manufacturers.
Maybe you can find processing guidelines for your type of stone? Do you have a neutral expert who could support you with this?
Best regards! mini_g!
Domski
9 Oct 2019 10:41
If the blocks have insulation filling, the wall crowns need to be covered. Everything else will dry out again. Or is it a timber-framed house?
Z
Zaba12
9 Oct 2019 11:16
You can’t really do anything until the roof is on! Water will always leak in somewhere.
We only got our basement "dry" (at least no more rain was coming in) after the roof was installed. We had to remove the puddles ourselves with buckets, a shovel, and cloths in freezing temperatures.
