ᐅ New Construction with Basement | Waterproof Concrete plus Perimeter Drainage
Created on: 5 May 2021 10:55
Hotdogxxxx
Hello knowledgeable people,
We are planning to build a new house with a basement. According to the soil survey, the ground up to a depth of about 5 meters (16 feet) consists of impermeable glacial till. Below that is permeable sand. There is no problem with rising groundwater here. However, due to the soil, surface water can be directed towards the basement wall.
The expert says the basement could be constructed either with masonry and drainage boards on the walls or with waterproof concrete. For masonry, a perimeter drain with a sump pit should be considered. If waterproof concrete is used, the expert states that no drainage is necessary.
The construction company recommends a masonry basement with waterproofing against hydrostatic pressure and perimeter insulation boards. Additionally, a perimeter drain and a sump pit should be installed. Alternatively, they suggest using waterproof concrete with open water management. However, they generally still recommend a perimeter drain with a sump pit for waterproof concrete to avoid long-term problems.
These measures/recommendations would increase the cost of a masonry basement by about €17,000 and for waterproof concrete by €7,000 with open water management or €16,000 with perimeter drainage and sump pit.
Basically, we would lean towards using waterproof concrete, but the recommendation to still install drainage seems a bit like a double safety net to us. The construction company justifies this because of the hydrostatic pressure and the expected higher humidity in the basement due to capillary action.
Since we are building the house with a central ventilation system, connecting the basement rooms to it would be straightforward.
We now have to decide what to do and are a bit unsure. What is your opinion? Does anyone have experience with waterproof concrete and glacial till soil? Is moisture an issue here?
Thank you very much for your input.
hanghaus20006 May 2021 13:39The rainwater is definitely more polluted than the water coming from the drainage.
hanghaus20006 May 2021 13:45Hotdogxxxx schrieb:
Since we really have no idea, we are most likely the perfect "cash cow"!! The contractor wants to sell you the drainage pit and the cistern? I was right. "The contractor only wants what's best for you."
Hotdogxxxx6 May 2021 13:52No, it’s not that bad! 🙂
At first, we talked about a rainwater tank, but he said it would probably be cheaper to outsource the installation and have it done by the landscaper.
Only later in the planning stage did we decide on a basement.
What annoys me is that this option wasn’t brought up again, even though it is a possibility. However, I need to check whether it is allowed to discharge excess water from the rainwater tank into the sewer system.
Since it is possible to feed water from the roof into the system, it should also be allowed for the rainwater tank.
hanghaus20006 May 2021 13:56Does the contractor already have the contract?
Including the cistern in the construction makes sense if you are building a basement. Without a basement, it is probably better handled by the landscaper.
Hotdogxxxx6 May 2021 14:06hanghaus2000 schrieb:
Has the contractor already been hired?No, no contract has been awarded yet.
We are planning a turnkey build and have now reached the point where we need to make a decision on how to proceed. Basically, we were waiting for the soil report to decide on the construction method for the basement.
Therefore, I really appreciate your input! I will now approach the contractor about the waterproof concrete (white tank) and bring up the cistern again. This is certainly the most cost-effective option!
hanghaus20006 May 2021 14:20Why not suggest my post #11 to the contractor? It could save both them and you quite a bit.
