ᐅ Network Planning in an Existing House – Cable Ducts or Conduits?
Created on: 1 Sep 2021 13:00
O
Orandus
There are 4 of us living here (2 adults, 2 children) in a terraced house built around 1980.
Basement: 2 storage rooms, 1 guest/music/hobby room.
Ground floor: Living room, kitchen, guest toilet
First floor: Children's rooms, bathroom, laundry room
Attic: Bedroom, office
The problem: We haven't been able to establish a stable Wi-Fi network. There are constant drops or fluctuations in speed. When it does work, I get about 80 Mbit download and 40 Mbit upload in the office/attic, but it’s not stable.
Previous solutions: Several attempts with Wi-Fi repeaters, then additionally Powerline adapters, and currently 4 Telekom mesh repeaters plus a Telekom Wi-Fi router are in use.
Planned solution: Switching to the Ubiquiti Unifi series including Dream Machine Pro (DMP), a 24-port PoE switch, and various Wi-Fi 6 access points. TVs, printers, PCs, NAS, and smart home bridges are to be connected by cable, while mobile devices will be served via the access points.
I would now like to ask for your opinion:
The plan is to set up a small network cabinet with the DMP and switch in one of the basement storage rooms. From there, two holes will be drilled through the ceiling into the living room (where a new floor will be installed anyway) so that I can reach both sides of the living room and install 2 or 4 sockets. On one side, an additional hole will be drilled from the living room into one of the children’s rooms, through which 2 more duplex cables will be routed upstairs to provide LAN to both children's rooms (the two rooms are next to each other, I would then drill another hole through the wall).
To supply the attic and to mount the access points, which are intended to be installed on the corridor ceilings of the ground, first floor, and attic, I can’t think of a better solution than running cables through the open staircase and using a long cable trunking there, from which individual cables will be distributed via smaller cable trunking to the corridor ceilings. The staircase is located right next to the storage room with the network cabinet, so a simple hole can be drilled there as well.
All cables will be concealed in screwed cable trunking since otherwise too many rooms would require renovation. They will terminate in dual keystone surface-mount boxes or directly in the access points on the ceiling.
I don't like the many cable trunkings. Possibly, I can route the cables in the living room through chases in the screed since, as mentioned, new flooring will be installed anyway. In the children’s rooms, the trunkings don’t bother as they will be installed close to the floor along the wall and mostly hidden by furniture. What bothers me most at the moment is the long run through the stairwell using trunking, but we currently lack the time and budget for a full renovation including in-wall cabling. If nothing better comes to mind, it will have to be done this way. The stairwell is fairly dark during the day, so possibly I can paint the trunkings to match the wall color.
Is there anything important I should be aware of? The holes drilled from the basement into the living room on both sides will each carry 3 duplex cables, so 6 cables in total, which means quite large holes through the reinforced concrete ceiling. I will have these drilled professionally. Is there anything to consider when selecting the cable trunking? At most, 4 duplex plus 3 single cables—that is 7 cables—will run through one trunking. What surprises me is that trunking apparently only comes in 2-meter lengths. Longer pieces would be better for the stairwell to avoid connectors in the middle…
Can you think of anything I might overlook or should keep in mind during the planning?
Orandus
Tarnari4 Nov 2021 22:44
kurzy schrieb:
Addendum: The new DreamMachine Pro SE costs about 100 euros more than the standard version and now includes 8 PoE ports.
Honestly, we're building houses worth 400K to 1,000K euros. I don't worry about a switch in that context. I would always choose a PoE switch that can cover every outlet in the house. I have no patience and no time to spend a few hundred euros over and over again for the rest of my life every time there's a change at the patch panel.
Cover all ports with PoE and never have to think about where to connect the DECT base station, access points, etc. — just plug and play.
Seriously. We're talking about 250 to 800 euros depending on the requirements. And that's for a house worth several hundred thousand euros.
11ant5 Nov 2021 15:36
Tarnari schrieb:
To be honest, we build houses here worth between 400K and 1,000K €.
I would rather say 0.4 to 1.0 million EUR ;-)
