ᐅ Neighbor’s concrete posts on our property
Created on: 8 Jul 2020 17:32
M4rvin
Hi everyone,
I just got home and I am shocked...
The neighbors had to retain about 60cm (24 inches) in height and now they have installed curbstones right on the property line.
Strangely, the entire concrete retaining wall is actually on our property!
Oh, and our green manure cover crop has been completely trampled, and our small garden bed has been concreted over.
What can I do?
Small girl looking at a construction site with concrete block, wooden formwork, and reinforcement at the foundation
Long concrete edge separating excavation pit (left) from lawn area (right), construction equipment visible.
Daniel-Sp
8 Jul 2020 18:24
I would never put a picture of my children on the internet...
If it bothers you, which I can understand, talk to the neighbor, demand the restoration of your property, and implement a different solution.
shenja
8 Jul 2020 18:27
We also placed L-shaped blocks towards the neighbor, but in a way that the concrete is on our property. I wouldn’t accept it like that. The neighbors need to contain it, and, of course, on their own property. It looks really unsightly.
seat888 Jul 2020 18:33
As my predecessor already mentioned, I would insist that if he needs to intercept, he should definitely do it on his own property. A retaining wall is fine, but he must position it so that it ends exactly at the boundary, and his curbs or L-shaped stones or whatever else accordingly placed just inside the boundary on his property.
danixf
8 Jul 2020 18:34
The elevation planning in the development area seems to have been handled poorly. Each plot has a different level, and the last one has to deal with the consequences.
There are L-shaped retaining walls that are only 6 cm (2.4 inches) thick. I don’t understand why 10 cm (4 inches) thick ones are used there. Visually, as a boundary where there will probably only be flower beds or lawn later, it doesn’t look good.
M4rvin8 Jul 2020 18:39
You are right, the height planning here is an absolute disaster!
What would my rights be as the affected party? Am I allowed to remove the concrete on my property?
guckuck2
8 Jul 2020 18:43
The concrete belongs on its side. It looks obviously awkward when it starts with L-shaped blocks, because then the edging would have to be offset and would no longer form a straight line... let’s see how the landscape gardener plans to solve this, but in any case, they will probably remove the edging again (at least that’s what I would expect).
Apart from that, to also point this out to the original poster, you don’t plant so close to the property line when the neighbor hasn’t even prepared their site yet. It’s hardly possible to work without causing damage in that case.
