ᐅ Need help with the planning and organization
Created on: 21 May 2016 15:29
karamella78
karamella78
21 May 2016 15:29
Hello dear professional craftsmen,
I need to order some parts for my Faktum kitchen, but I can only buy them online.
Therefore, I would appreciate some help from you.
It would be very kind if you could tell me everything I need for the assembly.
I am buying a base cabinet carcass for a cooktop. The size of the carcass is 80x70cm (31½x27½ inches).
I also need the legs for it.
Now, about the doors...
For the 80x70cm (31½x27½ inches) size, only the drawer front is available. What do I need for a drawer front? Which drawers? Which hinges? And what is a cooktop trim panel?
Do I need the NYTTIG divider for the cooktop?
Alternatively, if I use two doors in 40x57cm (15¾x22½ inches), I could have a drawer above with the size 80x13cm (31½x5 inches), but is that allowed if I want to install an induction cooktop above—meaning a drawer under the cooktop?
The next element is a tall cabinet carcass 60x195cm (23½x76¾ inches) (with legs it is 60x211cm / 23½x83 inches) for a built-in oven.
What do I need for that (besides legs, shelves, etc.)?
What are panels (blanks)?
Can I install any standard built-in oven there, or does it have to be from IKEA?
Your KARAMELLA
Thank you for your help! Have a nice day.
IKEA-Experte
21 May 2016 20:17
first, two questions.
Which front model do you have?
What should be below and above the oven (drawers, wire baskets, built-in height of the oven)?
The appliance does not have to be from IKEA.
karamella78
21 May 2016 21:31
Hi IKEA expert,
Since we took over the kitchen, we don’t know which fronts they are. They have a smooth surface (not high gloss, in off-white).
I want to replace all the fronts anyway and choose APPLÅD in white.
So the fronts will be APPLÅD white.
Does anything change if the fronts are different?
Above the oven, I plan to have a door measuring 60x57cm (24x22 inches), with just a shelf behind it, and below the oven a door 60x70cm (24x28 inches) also with only a shelf.
For the stove, I’m not sure if I’m allowed to install a drawer underneath.
One more question: if I choose an 80cm (32 inches) cooktop, is an 80cm (32 inches) wide base cabinet sufficient, or would it need to be 90cm (36 inches) wide?
Thanks!
