ᐅ Natural-style garden with hedge instead of fence (boundary hedge instead of fence)
Created on: 14 Apr 2019 17:52
Müllerin
I still owe you some garden photos...
As I’ve mentioned a few times before, we’re getting an “eco garden.”
After the excavation spoil from both halves of the house, which was just lying around here, was finally removed in September, nothing happened for a while.
At the end of March, it looked like this
Then I planted the hedge (with the gardeners).
On the outside there is a lot of hawthorn, then 2 holly bushes (we’ll see if they don’t dry out too much in summer), 2 firethorns, a witch hazel, a butterfly bush, 2 copper mountain ashes, spireas, a viburnum, and a mock orange. Up front, separately, a maple.
Eventually, there will be a rose arch with a gate at the end of the path.
The lawn is growing rather slowly; it’s just too cold right now.
In the raised bed there are herbs and a few flowers, and in the mulched bed only blue/white/pink flowers will bloom. A privet hedge will be planted along the border this week. Luckily, I was able to convince our neighbors not to go for anything like thuja or cherry laurel or anything similarly horrible. (Actually, it was pretty simple: I would have refused to plant that stuff in our garden. That would have meant installing a fence, and they would have had to pay for the hedge themselves.)
If you don’t prune privet to a blocky shape, it flowers beautifully.
Here’s a lilac; over Easter, vegetables will go into the raised bed, and on the right side towards the neighbors there will be a large bed in orange/yellow/red.
Yes.
Eventually, there will be an apple tree, once we find a tasty variety that the child isn’t allergic to.
I’d also like to add some kind of water feature, but we’ll see how that works without a fence with so many children around. Probably not at all.
We’ll see how it all turns out, but a gardener needs patience.
And here we’ll have the only nature-friendly garden; all around us there are golf-course lawns, gabions, dull uniform beech hedges, and hardly any flower beds.
Yes.
Pinkiponk18 Aug 2020 09:22guckuck2 schrieb:
Do you need a seminar on how to quote properly?Because I should have put "Herr von Ribbeck" in quotation marks? Or what did you mean?Pinkiponk schrieb:
Because I should have put "Herr von Ribbeck" in quotation marks? Or what did you mean?No, because you post a separate reply for every quote. The last 15 posts (2 pages) were almost all from you, which makes it a bit tedious to read. You can use the +quote function to select multiple posts at once, then click "Insert quotes" in the reply box and add your comment to each quote.P
Pinkiponk18 Aug 2020 10:07guckuck2 schrieb:
Do you need a citation tutorial?Thank you for the tip.Tamstar schrieb:
You can use the +Quote function to select multiple posts at once, then click "Insert quotes" at the bottom of the reply box and add your comments to each quote.Now I understand.I did not know this before. I’m sorry if I annoyed you. Thank you for your patience with me.
