ᐅ Is it practical to nail a KALLAX back panel between modules?
Created on: 14 Jul 2020 08:37
sikareo
Hello everyone, I have a question that has been on my mind recently: Is it really practical and advisable to fasten the back panels of IKEA KALLAX units together by nailing or using similar methods when assembling multiple modules? Specifically, I’m referring to the thin OSB boards that serve as the back panels of each KALLAX unit—when placing several modules side by side or stacked, it’s theoretically possible to screw or nail these back panels together.
I’m asking because, on one hand, I want a stable construction, especially if the assembly needs to be moved or is expected to bear heavy loads. On the other hand, I’m wondering if this method might damage the back panels, make the boxes harder to remove, or make the shelf more expensive or complicated to repair in case of minor damage.
Has anyone had experience nailing together KALLAX back panels between modules and can say whether it actually makes sense in terms of stability, durability, and practical use? Are there perhaps better alternatives? I would appreciate a detailed assessment!
bulanau
15 Jul 2020 09:52
Demetrius schrieb:
However, disassembling it later became difficult because the back panels had become quite brittle
This is a very important point, which I can confirm: OSB boards do not tolerate repeated removal of nails or screws. The material is not flexible and tends to crack under such stress.
Therefore, if the back panels must be connected, I recommend lightly beveling the joint areas beforehand or placing small leather or felt pads as protection under the fasteners. Pre-drilling is also advisable to prevent splitting.
On the other hand, small furniture connectors or flat metal brackets are often much better and can be removed again even after a long time.
Rashadmeo
15 Jul 2020 10:20
I really like nailing it together!!! 🙂 I did this myself and found that it holds super securely! For people who want the shelf to stay firmly in one place, this is really great. The modules no longer slide apart, and everything feels even more stable. 🙂
Honestly, if you work carefully and precisely, the back panel material isn’t that fragile. Just gently set the nails, and it works!
And the cool thing is: if you want to change it later, you can carefully pull the nails out again. I’m really happy with my solution!!!
FEKAU
15 Jul 2020 11:44
That is correct, but the issue besides stability is also the durability of the connection and the possibility of later disassembly.
Rashadmeo schrieb:
if you work precisely and carefully, the back panel material is not that fragile
I would add that even precise workmanship cannot prevent the material from aging-related damage and breakage during frequent adjustments. For uses intended to last long without disassembly, nailing the parts together is a solution, but one I only recommend with reservations. For furniture construction with modularity, I recommend mechanical fasteners that do not penetrate the wood.
bupar
16 Jul 2020 09:31
Based on my experience with several KALLAX assemblies, I generally recommend not attaching back panels with nails. The thin OSB boards are too fragile and can break more easily.
For a durable connection without damage, flat dowels or special connectors with tabs that fit into grooves are suitable. This results in a significantly more stable overall structure and allows the modules to be separated easily if needed.
Moreover, back panels are not designed to withstand tensile or shear forces that occur when modules are nailed together. This leads to suboptimal load distribution.
A proper connection should take this into account and transfer the loads to the side panels or sturdy connecting plates.
retau
16 Jul 2020 11:02
Great discussion here! I agree that nailing the back panels often works really well and makes a lot of sense! 🙂
I once had a large shelf that was always a bit wobbly. After nailing the back panels, the whole shelf became rock solid – really impressive!
If you work carefully, check all four corners precisely, and use short nails, you can save yourself expensive specialty connectors. I think this is a simple solution that provides great results for home use.
So, don’t hesitate and give your KALLAX units new stability this way! 😉
