ᐅ My Wood-Fired Oven in the Garden – A Dream Comes True!
Created on: 19 Aug 2020 10:55
Climbee
Climbee19 Aug 2020 10:55
With our new house, I finally became the proud owner of a wood-fired oven in the garden. I had been dreaming of this for such a long time! Baking your own bread, and doing it properly in an oven that was heated with wood beforehand.
The installation took place as part of the garden landscaping, although the garden landscaper didn’t do the work. My husband built the foundation, and then a stove setter installed the oven.
The masonry foundation:
Outdoor area: light gray terrace slabs in steps, concrete blocks, wooden house wall on the right, round lid.
Now plastered:
Garden construction site: concrete blocks forming a wall, wooden boards lying next to it, gloves on the edge.
Then brick lintels were placed on top:
Garden terrace with wooden furniture, construction tools, green hose, and planted beds.
And finally, the oven was installed (it was a kit from Kandern Feuerfest):
Garden area with white exterior oven on stone base, wooden bench and pallets in front.
On top, granite slabs were added, and the work surface next to the oven now also has a granite slab that we had cut to size.
After a few days, the oven was cured. This meant starting slowly with small loads of wood until it was possible to use the full amount, making the oven fully operational. This is a process that takes several days:
Outdoor baking oven made of concrete, open fire chamber with burning wood fire.
Finally, we were able to use the oven for the first time! Since I didn’t have any sourdough starter yet, we baked a bread using ready-made sourdough (which can no longer be used as a leavening agent, but only adds flavor) and a ciabatta:
Rustic dark loaf of bread with slices and knife on wooden board.
We were already very impressed. You can always use the residual heat for all kinds of slow-cooked dishes:
In the oven: white casserole dish with red tomato vegetables and herbs; bread next to it.
By now, we have become pros. Whether venison leg, layered meat, rabbit, or goulash — there is always something we put into the oven after baking bread, and without any extra effort, we have wonderfully tender meat dishes after a few hours or overnight.
Of course, you need to upgrade your equipment:
White cleaning tool with brush head lying on wooden table; next to it two metal rods.
A bread peel and a fire rake with a brush to clean the baking chamber after heating. We knew that we would need these.
Musketier19 Aug 2020 11:10
The bread looks good. Do you make sourdough bread?
Climbee19 Aug 2020 11:18
What caught us off guard was that our Kitchen Aid didn’t really get us anywhere with bread baking. It’s actually quite a sturdy stand mixer, but its maximum dough capacity is 1kg (2.2 lbs) — just enough for a single loaf. But you don’t heat up an entire oven for just one loaf; it needs to be worth the effort, and both the Kitchen Aid and the baker were reaching their limits.
The Kitchen Aid can only run for a maximum of 10 minutes at a time — which is already necessary just for one loaf. When you want to bake 5 or more loaves, the little machine really struggles. So does the baker. That means the dough for each loaf has to be made separately.
That’s quite a lot of work and barely acceptable timewise.
So, we started looking for a dough kneading machine (DKM). At first, I was very optimistic. Given the many pizzerias closing during the pandemic, surely a used DKM could be found! Well, yes — but not necessarily what you want. Eventually, we decided: the dough bowl had to be removable so we could work with two, enabling us to make two different types of bread without much hassle.
That rules out most pizzeria machines right away, since their bowls are fixed.
The bowl also needed to be large enough to allow the dough to rise inside it. For 5 - 6kg (11 - 13 lbs) of dough, the machine must be sized for at least 10 - 12kg (22 - 26 lbs) of dough capacity.
In the end, only the Häussler DKM fit the bill — either the 14kg (31 lbs) or the 18kg (40 lbs) version. The price difference wasn’t significant, so naturally we went for the larger one! With two bowls and the matching cover hood, baking could finally begin!
We were very lucky to find a used machine that met our needs perfectly. These machines hold their value extremely well, so my new treasure is already of age — 18 years old. But it still looks almost new:
Large white kitchen mixer with open lid; several dough bowls with yeast dough next to it.
The picture above is from the machine’s first run last weekend. To test it, we brought 10kg (22 lbs) of flour — the stated maximum amount — and mixed it with water.
The machine ran smoothly, and we came home with a full dough bowl holding about 9kg (20 lbs) of flour mixed with water — still quite a lot!
Somehow, I couldn’t just throw away the lump of flour, so I made yeast dough out of it. I set aside a bit for fresh Sunday rolls, made Bohemian dumplings for dinner, and the rest became sweet yeast dough. You can see the result above. Altogether, that ended up being around 15kg (33 lbs) of yeast dough, and I baked like crazy (in the regular oven; there was no time to heat up the wood oven).
One tray of crumble cake and about 150 cinnamon rolls later, I gave up and froze the rest in portions. We probably have enough yeast dough stocked up for the whole extended family for the next two years…
And then, of course, it was finally time to bake bread with it. A bread baking day requires at least a day of preparation. By now, I’m also a proud owner of several home-cultivated sourdough starters (my husband is always teasing me: “So, how are your pets doing?”), and sourdough bread takes some planning. So, I prepped on Monday and yesterday was the big baking day!
This time it was pumpkin crust bread and a rye bread with a three-stage fermentation (which makes it especially digestible).
Finally, the new machine got its proper use!
It really makes a difference whether you have to make dough for each loaf separately or can just mix 5kg (11 lbs) of dough in one go! It’s so much faster, and the machine barely breaks a sweat. My poor little Kitchen Aid would have groaned and given up.
Here’s some pictures of the final proofing in proofing baskets (or, lacking proofing baskets, various bowls):
Several round loaves resting in cloth-lined proofing baskets on a kitchen counter; sunflowers in vase in background.
Just before loading into the oven:
A dough ball on a wooden peel next to bags of flour on a granite slab outdoors.
Finally, the oven is full!
Round loaves dusted with flour resting in a stone oven on a baking stone.
And after an hour, the bread is done:
Eleven round loaves with dark, crispy crust on a grey granite slab against a white wall.
Dark bread on a wooden board; a slice broken off with a knife beside it; kitchen background.
The oven still needs to be plastered at some point, then it will be finished.
Of course, pizza works too, but that requires higher temperatures than bread baking and the fire stays in the oven chamber. My brother is our pizza expert, and I’ll share pictures from our next family pizza session!
Lumpi_LE
19 Aug 2020 11:18
Great, that is still pending for my Project 73.
Climbee19 Aug 2020 11:19
Musketier: if possible, only with sourdough – I much prefer that.
Although yesterday’s pumpkin-crust dough included 20g (0.7 oz) of yeast for 4kg (8.8 lbs) of dough.
Bookstar
19 Aug 2020 12:46
Cool, but that would be way too much effort for me... I’d rather go to the bakery.
But I do want to say, as a big pizza fan.
