ᐅ My pet is scratching the side panel of the Kallax shelf unit – how can I prevent this?
Created on: 28 Apr 2020 13:07
Meremingto
I have a small problem with my pet, specifically my cat. She keeps scratching the side panel of my Kallax shelving unit, not just occasionally, but quite regularly and fairly intensely. I suspect it’s either about claw maintenance or marking her territory. The shelf is made of wood or wood-based panels, and the side panels seem to be especially attractive to her for this behavior.
My main question is: What practical and sustainable methods are there to prevent scratching specifically on this side panel, without harming my cat or overly restricting her? I’m looking for suggestions that address both the cat’s behavior and protecting the furniture.
So far, I’ve only considered covering the affected area with some kind of protective film or offering alternatives like scratching posts, but I’m unsure how effective that will be with persistent behavior.
I look forward to your tips and experiences!
I notice that the suggestion to apply protective film comes from several people, which basically makes sense. However, I wonder how durable this measure really is, especially with active cats. Films can peel off, which then makes the temptation even greater.
Also, are there any studies or experience reports on how effective pheromone diffusers are in reducing scratching behavior? I believe a combination of behavior modification and physical protection is necessary, but I am also skeptical that positive reinforcement alone is sufficient.
Does anyone have reliable sources or experience?
In summary, from my perspective:
- Scratching by cats is instinctive, serving claw maintenance and territory marking.
- Protective film physically shields furniture but does not influence the cat’s behavior.
- The most effective approach is a combination of behavior guidance (providing scratching posts or furniture in the same location) and physical protection.
- Pheromone diffusers can have a positive effect on surrounding areas.
I also recommend sanding or reinforcing the side panel with laminate if protective film is not an option.
Additionally, it is important to observe the cat to determine if the scratching impulse is influenced by health issues (e.g., parasites, pain).
Please let us know if the cat shows any other unusual signs.
Meremingto29 Apr 2020 11:47Thanks already for the many responses!
I’ll try to provide more details to maybe help focus the discussion:
- It’s a 2-year-old neutered house cat, no specific breed traits.
- The apartment is about 70 sqm (750 sq ft), the Kallax unit is in the living room, right next to a window wall.
- The cat already uses a large scratching post, a smaller scratching post, and various scratching mats, but clearly hasn’t adopted the side panel of the Kallax as a personal scratching surface yet.
- She mainly scratches only this side panel, not the rest of the shelf or other furniture.
- Otherwise, she seems well balanced, gets plenty of playtime, outdoor walks are not an option for her.
What puzzles me in particular is that she stubbornly prefers this one surface, even though other options are fully available.
@TYRELL Regarding your point: True, I haven’t really considered the idea of a pheromone diffuser yet – does that actually affect scratching behavior?
Looking forward to more suggestions!
Additional information: Pheromone diffusers like Feliway mimic the facial pheromones of cats, which they use to mark their territory as safe. Studies have shown that using these diffusers can reduce anxiety and stress-related behaviors in cats.
Results are mixed regarding scratching behavior, but when combined with appropriate scratching alternatives, they can help reduce scratching in unwanted areas.
Furthermore, the surface texture of the Kallax side panel can be examined: Some rough or textured surfaces are particularly attractive to cats as scratching objects. A smooth coating might reduce this attraction.
Conclusion: Use a pheromone diffuser, but also provide mechanical protection and properly placed scratching alternatives.
Kyler10 schrieb:
Pheromone diffusers like Feliway mimic the facial pheromones of catsThis can really work wonders! If you haven’t tried it yet, it’s definitely worth a shot – a small, quick device that can sometimes create a really calming effect.
And hey, how about spraying some catnip on the scratching furniture? For me, it not only keeps my tomcat busy but also makes him enjoy scratching. Sometimes a little attractant is needed for the feline to give in 😉
ritotar schrieb:
how about spraying a little catnip on the scratching furniture?I generally recommend using catnip in moderation, as not every cat reacts the same way and some may even become overstimulated. Overall, it’s a good addition to make scratching posts more appealing.
Also: Even if a cat seems calm, it can help to direct the scratching impulse through playful training using a clicker or other methods.
There are also special sprays available that make furniture smell or taste unpleasant to cats – however, you should be careful with these to avoid harming your bond with the animal.
Important: In the long run, understanding the underlying cause is essential.
