ᐅ My pet is scratching the side panel of the Kallax shelf unit – how can I prevent this?
Created on: 28 Apr 2020 13:07
Meremingto
Meremingto
28 Apr 2020 13:07
I have a small problem with my pet, specifically my cat. She keeps scratching the side panel of my Kallax shelving unit, not just occasionally, but quite regularly and fairly intensely. I suspect it’s either about claw maintenance or marking her territory. The shelf is made of wood or wood-based panels, and the side panels seem to be especially attractive to her for this behavior.
My main question is: What practical and sustainable methods are there to prevent scratching specifically on this side panel, without harming my cat or overly restricting her? I’m looking for suggestions that address both the cat’s behavior and protecting the furniture.
So far, I’ve only considered covering the affected area with some kind of protective film or offering alternatives like scratching posts, but I’m unsure how effective that will be with persistent behavior.
I look forward to your tips and experiences!
COLEBAR
28 Apr 2020 13:14
Hello, simply cover the side wall with scratch protection film or a piece of carpet. Alternatively, place a scratching post nearby and attract the cat there using toys. This usually works well.
ritotar
28 Apr 2020 14:22
Hey! Cats are real scratch experts and can sometimes be rebellious when it comes to furniture ;-) If I were you, I would definitely create several attractive areas where they are allowed to scratch – a cozy scratching post, cardboard, or sisal mats. Then, maybe put some double-sided tape on the side of the Kallax unit, as cats often dislike that!
Good luck, patience usually helps here 🙂
Grace
28 Apr 2020 15:03
Hello Meremingto,
I am familiar with this issue. Cats use scratching to maintain their claws, mark their territory, and reduce stress. It is important to provide your cat with enough alternatives, ideally in the areas they currently prefer.
Therefore, I recommend:
- Scratching posts or mats made of sisal placed close to the side of the Kallax unit.
- Increasing playtime and stimulation to reduce stress as a cause of excessive scratching.
- Applying a protective film or laminate to the side surfaces to protect the area.
It is important never to respond aggressively or push the cat away. You can also use catnip in the allowed areas to help guide your cat there.
Does the cat need more hiding places? Sometimes scratching is also caused by boredom or a lack of activity.
TYRELL
28 Apr 2020 16:41
Hello, to permanently correct the behavior, we need to understand the full context:
1. What kind of cat is it (breed, age, sex, whether neutered)?
2. What is the living environment like? Are there other scratching options available?
3. Is the behavior shown only on the Kallax side panel or elsewhere as well?
Cats instinctively scratch to maintain their claws and to mark territory with scent glands in their paws. The side panel of the Kallax shelf is likely perceived as an attractive spot because of its texture or location (line of sight, escape route, etc.).
My recommendation:
- Create a detailed overview of the existing scratching furniture and their accessibility.
- Place a sisal scratching post near the Kallax, ideally with the same texture or at least similar stimuli.
- Mechanically protect the side panel with a lightly adhesive protective film, such as a common furniture film, slightly transparent.
- Additionally, a pheromone diffuser (such as Feliway or similar) can help to calm the cat.
It is important not to respond to the behavior with punishment, as this can cause fear and worsen unwanted behavior.
Could you provide more information about the cat’s environment and behavior?
Tause
28 Apr 2020 17:19
I believe that before immediately using protective covers or distractions, it’s important to observe the cat’s actual behavior more closely. It is often underestimated that animals release stress or communicate with their environment through scratching.
Also, are we sure that the side panel of the Kallax is really the main issue, or could the cat be reacting to other stress factors in its surroundings?
Perhaps the cause is that your pet needs more physical or mental stimulation. Sometimes simply using furniture protectors does not solve the problem if the underlying trigger is not addressed.
