ᐅ My KALLAX was repainted after fire damage – will the paint hold up?
Created on: 25 Oct 2022 18:27
Mufar70
Hello everyone, I have a somewhat unusual question: My KALLAX shelf from IKEA was recently heavily soot-stained and damaged due to a nearby fire. I thoroughly cleaned the shelf and then repainted it to cover the visual damage. My question is: Will the paint adhere well to a surface that was previously heavily exposed and heat-damaged? Does anyone have experience with whether a new coating on the KALLAX will last permanently despite fire damage, or if it will peel off soon? I used a water-based wood paint that should be suitable, but I’m unsure because of the heat exposure and possibly remaining residues. Thanks in advance for your feedback!
Garry
26 Oct 2022 18:22
bupar schrieb:
If the wood is deeply damaged by heat, the paint will not adhere properly
This is the crucial point. In fire damage, the surface can change, becoming porous and uneven. It is advisable to test the adhesion by applying a sample of the paint beforehand.
If you do not have professional materials available, a special wood sealer can help to seal residues and significantly improve paint adhesion. This way, you can better control the effect of heat residues.
Also important: The environment should be dust-free and dry when repainting.
BARSAN
27 Oct 2022 08:54
If the KALLAX was very badly covered with soot, the paint can deteriorate more quickly due to the residues. Soot absorbs a lot. So make sure to clean it thoroughly and apply a sealing primer. Otherwise, the paint will peel off quickly.
Repar
27 Oct 2022 13:47
One more point: If you have no experience with wood finishes, water-based acrylic paints are usually the best option. They are durable and adhere well if the wood is properly prepared. Sanding, cleaning, primer, and applying thin coats will ensure the paint lasts.
