ᐅ My KALLAX unit is placed on a radiant floor heating system – any impact?
Created on: 17 Apr 2024 08:37
Liko10
Hello everyone, I have a somewhat specific question: My KALLAX shelf is placed exactly on the spot in my apartment where there is underfloor heating. What long-term effects could this have on the furniture?
I’m asking because the shelf is standing directly on the floor, and I’m concerned whether the wood or wood-based panels might warp or even get damaged due to the heat. Does anyone have experience with the combination of underfloor heating and furniture placed directly on top of it? Are there any special recommendations or warnings I should be aware of?
Thanks in advance for your insights!
kasan
19 Apr 2024 09:01
Greglau schrieb:
Direct contact increases the risk of minor deformation or discoloration.
That is an interesting point, but it would be necessary to quantify how high this risk actually is.
Does anyone have concrete experience or data on the temperature range at which laminate or particleboard gets damaged? I mean, many underfloor heating systems operate above 30°C (86°F), especially in winter when they don’t always run at very low temperatures.
PeoDaniel
20 Apr 2024 11:33
kasan schrieb:
Does anyone have specific experience or data regarding the temperature ranges at which laminate flooring or particleboard get damaged?
Typical particleboard is heat-resistant up to about 60–80°C (140–176°F), but the decorative foil can be damaged at much lower temperatures—around 40°C (104°F), adhesives might loosen or discoloration can occur.
Since underfloor heating systems rarely exceed 30°C (86°F) surface temperature, usually there is no issue. The risk is higher with constant overheating, but that is uncommon in living spaces.
My advice: measure the floor temperature, and if it exceeds 30°C (86°F), install a protective layer.
Luciandi
21 Apr 2024 08:17
I really appreciate how you’re discussing this topic here in a factual and helpful way, thanks for that!
I often wonder with topics like these: what would be the worst-case scenario?
Would it be just some minor visual distortions, or could the piece of furniture actually become unusable? What about the long-term effects – will something permanently deform?
My impression is that with furniture like KALLAX, which is more of an IKEA standard quality, it’s wise to be a bit cautious with heat, but serious damage is rarely an issue.
