ᐅ My KALLAX unit is no longer completely white after painting – any recommendations?
Created on: 13 Dec 2020 09:42
liruren
liruren
13 Dec 2020 09:42
I have a question regarding my KALLAX shelf from IKEA, which doesn't look as white as before after recent painting work at my home. Before the painting, the shelf was bright white, but now the surface appears somewhat dull, slightly discolored, and no longer looks fresh. I suspect that the white wall paint or possibly paint that got on the shelf during painting has affected the surface.
The shelf has been standing in the freshly painted room for about two weeks, and I want to avoid replacing it completely. I am considering how to restore the original color quality. Does anyone have experience with removing discoloration or the dull effect on the laminated MDF board of the KALLAX? Is it enough to clean the shelf thoroughly, or should I consider a special treatment, such as fine sandpaper or a new coating?
I also want to avoid damaging the material surface, so a gentle method would be ideal. Any advice, whether home remedies or products from specialized suppliers, would be very helpful.
Thank you in advance for your recommendations!
Z
zartra
13 Dec 2020 10:06
liruren schrieb:
I suspect that the white wall paint, or possibly some paint that got onto the shelf during painting, has affected the surface.
First, clean with a mild dish soap. If that doesn't help, use some fine sandpaper (grit 400+) and gently sand in the direction of the grain.
Then treat with furniture polish to restore the shine.
Surela
14 Dec 2020 08:27
zartra schrieb:
If that doesn’t help, use some fine sandpaper (grit 400+) and gently sand in the direction of the grain.
I would like to add and expand on that:
First of all, it is crucial to identify the exact type of surface on your KALLAX. The standard white surface is usually made of melamine-coated particleboard or MDF. This surface is quite sensitive to mechanical treatment. Therefore, sanding should be done very carefully and only as a last resort, as it can easily damage the coating.
If it’s just simple paint residue, I recommend first trying a thorough cleaning with solvent-free detergents, such as a mild dish soap or a specialized melamine cleaner for furniture.
If that is not enough, a light polishing with a fine abrasive pad (e.g., fine Scotch-Brite) can help without excessively damaging the surface. It is important to treat the surface after each step with a soft cloth and, if necessary, furniture polish or a care product suitable for melamine surfaces to restore shine and seal the material.
If the paint is really stuck on the surface, the best option is to use isopropanol (rubbing alcohol) or a special paint remover made for melamine-coated surfaces, tested first on an inconspicuous spot.
Important: Allow sufficient time for drying and airing out after all treatments.
Do you have more specific information about the type of discoloration? Do you know which kind of paint was used (acrylic, latex, emulsion) and whether it was still fresh or completely dry?
Guyju
14 Dec 2020 13:15
Hello liruren,
I’d like to add a brief guide on how to restore your KALLAX to its original shine after painting, based on my experience:
1. Surface cleaning: As zartra and Surela have already suggested, start with a mild, non-abrasive cleaner. Use warm water mixed with a small amount of dish soap and a soft cloth. Wipe the shelf thoroughly to remove paint residues and dust.
2. Testing a solution: Before using chemical agents, test them on an inconspicuous area. Isopropanol or acetone-based nail polish remover can help dissolve paint but are abrasive and may damage the surface!
3. Gentle sanding: If cleaning is not enough and paint marks remain, use very fine sandpaper (grit 400 to 600) or fine sanding pads. Be careful to sand lightly and only in the direction of the grain to avoid dull spots.
4. Aftercare: After sanding or cleaning, polish the surface, for example, with furniture polish designed for white or light-colored finishes. There are also special care products for melamine-coated furniture that protect the material and restore shine.
5. Prevention: For future projects, I recommend covering the furniture with plastic sheeting or painter’s fleece to minimize paint overspray.
If you’re unsure, avoid sanding large areas right away, as the melamine coating is essential for the white appearance.
Good luck with the restoration, feel free to ask if you have any questions!
