ᐅ My KALLAX unit got stained by spilled coffee – how can I clean it?
Created on: 16 Jan 2024 08:23
RialishaHello everyone,
I recently spilled coffee on my KALLAX unit. Now there are unpleasant brown stains on the surface, and I’m wondering what the best way is to remove them without damaging the material.
The KALLAX is made of MDF with a laminate finish, so I want to avoid causing further damage through moisture or incorrect cleaning products. Are there any proven home remedies or special cleaning products that effectively work without compromising the appearance?
Has anyone had experience with such stains on the KALLAX? I would appreciate any advice, preferably with guidance on the procedure and, if necessary, the amount of product to use.
Thanks in advance!
Thanks in advance!
Hey Rialisha,
oh dear, I know that all too well – coffee and furniture definitely don’t mix in the long run 😄!
For stains like that on KALLAX (the MDF with laminate), a mix of lukewarm water and a drop of mild dish soap often does the trick. Important: Don’t use too much water, or the MDF will soak it up and swell. Use a soft cloth and gently dab, don’t scrub too hard.
If that doesn’t work, sometimes a mild alcohol-based cleaner (isopropanol) can help – but test it first on an inconspicuous spot! It breaks down coffee oils and pigments without damaging the laminate.
Good luck, and next time keep the coffee a bit further away from the unit 😉!
Hello Rialisha,
I agree with Trate47 and recommend starting with a gentle cleaning using a mild detergent and a damp microfiber cloth.
It is important to observe how the material reacts to moisture. The KALLAX MDF frame absorbs water, so you should avoid working with too much liquid to prevent warping.
If the stains are heavily pigmented, a mixture of water and white vinegar (1:1) can be effective. Vinegar acts as a descaler and removes color particles without being harsh. Afterwards, wipe down thoroughly with clean water and allow to dry.
Please remember to test this on an inconspicuous area first to avoid any discoloration.
Wow, that’s really frustrating about the coffee spill! But don’t worry, it can usually be fixed quite well!
I once redecorated a KALLAX and had coffee stains on it too – a white eraser worked really well for me :-) Just gently rub it over the stain, sometimes the marks nearly disappear like magic!
And if that doesn’t work: try carefully rubbing a little lemon juice on a cloth over the stain, it can lighten the marks! But don’t scrub too hard, or the surface laminate might get damaged.
Fingers crossed you can get your favorite piece of furniture looking great again! 🙂
Hi Rialisha,
@Rialisha, I think it’s great that you specified the exact type of material, that’s really helpful!
@labar43, I’ve never heard of using an eraser for coffee stains either – sounds interesting! However, like @Vinlen, I would recommend trying mild methods first, since MDF with a foil surface can swell if exposed to too much acid or mechanical stress.
Sometimes special plastic cleaners (for furniture) can help; they are quite gentle and usually don’t leave a white residue. Just ask at a hardware store.
Important: Always clean from the outside toward the center so the stain doesn’t spread further. Also, avoid using rough sponges as they can scratch the material.
I would like to emphasize how important it is to treat the stain as quickly as possible. Coffee contains organic compounds that can penetrate the laminate over time, making cleaning more difficult.
In general, I recommend the following procedure:
1. Immediately dab the excess coffee with an absorbent, soft cloth – do not rub.
2. A solution of 50% water and 50% isopropyl alcohol is recommended, as alcohol effectively dissolves surface organic compounds and evaporates without adding moisture to the furniture body.
3. Use a soft cloth and work in circular motions without applying pressure.
4. If the stains remain visible after drying, you can carefully use a fine, non-abrasive plastic polish (e.g., meant for automotive paint) – this evens out micro-scratches and lightens stains.
5. Since the KALLAX has a laminate surface, it is essential to test the cleaning method on a barely visible corner first.
What I would also like to know is: How old is the furniture and does it already have surface damage? The cleaning results depend greatly on the condition.
Perhaps you could briefly add this information?
