ᐅ My KALLAX unit gets stained every time a flower pot falls on it – any quick solutions?
Created on: 7 Jun 2021 16:27
luismar
luismar
7 Jun 2021 16:27
I have an issue with my IKEA KALLAX shelving unit, specifically the module where I keep my plants. After several incidents where a flower pot has fallen, I noticed that the surface of the KALLAX module develops quite unpleasant stains each time – it looks like water or soil has somehow been absorbed into the surface or at least left marks. I have already tried cleaning with a damp cloth and mild detergent, but the stains don’t come off, which eventually makes the shelf look really unattractive.
I’m particularly interested in whether anyone knows a quick and effective way to remove these stains without damaging the KALLAX surface. Long-term solutions to make the shelving unit more resistant to such incidents would also be appreciated. Does anyone have tips on caring for KALLAX modules when used with flower pots? Thanks in advance for your help!
Kukar
7 Jun 2021 17:45
I would start by trying a special plastic cleaner if water stains are visible. Otherwise, a mixture of vinegar and water can help – just make sure not to apply it too aggressively. If the stains are caused by soil, they can be gently removed using a damp cloth and a little dish soap.
benfa
7 Jun 2021 19:08
luismar schrieb:
I am mainly interested in whether anyone knows a quick, effective solution that removes the stains without damaging the KALLAX surface.
Your question is well phrased, but you should keep in mind that KALLAX units are not specifically designed to handle water or soil. They consist of veneered particleboard, which naturally reacts to moisture. Before attempting any cleaning, it is important to determine how deep the stains have penetrated.
luismar schrieb:
Long-term solutions to make the shelf more resistant to such incidents
In this case, coasters or special wax coatings might help. Have you already tried anything like this? It is crucial to eliminate the source of moisture immediately and ideally line the shelf with protective mats or films.
KNUTGI
8 Jun 2021 08:22
Hey, I once had a similar flowerpot accident with my KALLAX, and I’d say, first of all, stay calm! 🙂
Water stains and soil on a piece like that are annoying but usually not the end of the world. It’s best to wipe off any spills immediately. For stubborn stains, I sometimes mix transparent baking powder with a little water and gently rub it on—kind of like a mild abrasive paste. This usually works surprisingly well and doesn’t damage the veneer.
A quick tip: placing a plastic tray under your plants helps a lot if another little accident happens. This way, your shelves stay clean, and you save yourself the hassle afterward. 🙂
benfa
8 Jun 2021 09:45
KNUTGI schrieb:
Water stains and dirt on such a component are annoying, but often not the end of the world.
I agree with you, the damage is often cosmetic. However, it strongly depends on whether the water stayed only on the surface or penetrated into the panels. The latter accelerates the spread of the damage many times over.
KNUTGI schrieb:
For stubborn stains, I’ve sometimes mixed transparent baking soda with a little water and gently scrubbed
That sounds interesting – please be careful that the baking soda is not too abrasive, as plastic surfaces can be scratched easily. A good idea would be to test whether the surface becomes dull afterwards, as this can visually alter the texture.
