ᐅ My Kallax unit is now too low after changing the carpet – how can I raise it?
Created on: 3 Feb 2024 09:17
Sylvester3
I have a Kallax shelf from Ikea that used to fit perfectly with the height of my apartment. Now I’ve changed the carpet in that room, and the new one is significantly thicker – so the shelf is now much too low. Specifically, the surface of the Kallax is several centimeters below the windowsill, which is both visually and functionally inconvenient.
Does anyone have a reliable and long-lasting solution to raise the height of the Kallax module without much effort or expensive remodeling? I’d prefer not to buy a completely new piece of furniture but rather use smart adjustments.
How can the shelf be raised safely and stably so it doesn’t wobble or tip over? I would appreciate practical tips for this specific issue!
KAULIS
4 Feb 2024 08:30
I would like to add that when using risers, you must pay close attention to their maximum load capacity. Kallax units are generally sturdy, but improper risers could compromise the structure under load.
Please also keep in mind that for DIY or non-standard solutions, the screw holes or attachment points must align precisely to avoid tension or deformation.
A safe option would clearly be using screw-on furniture legs with a specified load rating.
Trate47
5 Feb 2024 07:12
I had the same problem and built a kind of platform from simple wooden blocks. It was important to me that it stayed light in case I needed to move the shelf. I then added felt pads to prevent damage to the new carpet.
It doesn’t look bad at all, and I didn’t have to buy extra legs. Maybe this low-budget solution could work for you too. 😉
Sylvester3
5 Feb 2024 18:44
andre3 schrieb:
Make sure there is sufficient stabilization, especially when the shelf is loaded.
Thanks for the advice, I hadn’t fully considered that yet. I plan to store some heavier items there, so I don’t want to take any risks.
It would probably be safer to use adjustable feet or a base plate. Are there any reliable recommendations for models that fit well with Kallax? In the end, it also shouldn’t be too expensive.
I appreciate any tips!
andre3
6 Feb 2024 10:51
Sylvester3 schrieb:
It would probably be safer to use screw-on feet or a plinth board like that.
Exactly. Ikea offers a simple and affordable solution with their Capita feet, which can be mounted directly on Kallax units. They are sturdy, with a load capacity of about 30 kg (66 lbs) per foot, and easy to install.
If you prefer something more custom, adjustable furniture feet from a hardware store are recommended, which can also be screwed on. Just make sure they have a metal thread and a wide base plate for increased stability.
Summary: Screw-on feet are the most practical, stable, and easiest option to implement.
