ᐅ My KALLAX shelving unit rattles when music is playing – has anyone added any soundproofing or vibration damping?
Created on: 6 Jun 2022 10:18
JOFRA9
JOFRA9
6 Jun 2022 10:18
I have a somewhat unusual problem with my IKEA KALLAX shelving unit. Whenever music with some bass is playing, the unit rattles or vibrates unpleasantly, as if the individual compartments or shelves are resonating or moving slightly. The noise isn’t very loud but quite annoying, especially with bass-heavy music.
I suspect it might be due to the construction of the shelving unit or possibly insufficient fastening or insulation. Has anyone experienced this issue before and maybe dampened or reinforced the shelves or the entire unit?
If so: How exactly did you proceed? What materials did you use to dampen or secure it? Did the measures have a noticeable effect on reducing the rattling? Are there any specific tricks to eliminate these vibrations permanently without affecting the appearance or functionality?
I would be very grateful for any tips or shared experiences!
elgla
6 Jun 2022 11:03
JOFRA9 schrieb:
Whenever music with some bass plays, the shelf rattles or vibrates unpleasantly
That sounds really annoying, and I can understand how constant rattling can ruin the mood when listening to music. I once had a similar issue with an old sideboard that would shake during loud music.
I didn’t use any specific insulation at the time, but I found that a lack of proper stabilization of the back panel is often the cause. Have you properly screwed or fitted the back panel of the KALLAX unit? Sometimes it is loose, and the bass causes the shelf to resonate.
As a first step, I would recommend firmly and fully attaching the back panel, possibly adding extra screws or small corner brackets for support. After that, you could consider applying thin self-adhesive foam strips at the contact points to help dampen vibrations.
laureo
6 Jun 2022 12:47
The issue you described is a typical vibration problem that can occur with thin-walled furniture, such as the KALLAX.
In my experience, a combination of additional reinforcement and vibration dampening using flexible materials is the most effective solution.
For example, on a similar shelving unit, I attached a thin layer of acoustic foam behind the back panel, which helps reduce vibrations in the frequency range that produces bass. Similarly, applying felt pads or rubber strips to the contact points of the shelves significantly reduced rattling.
It is important that the shelves cannot vibrate freely. A firm but flexible connection provides damping. Keep in mind that a connection that is too rigid can sometimes cause other noises – so some experimentation is necessary.
kibutar
7 Jun 2022 09:21
JOFRA9 schrieb:
Has anyone here ever experienced this issue and maybe insulated or reinforced the shelves or the entire shelving unit?
The rattling during bass-heavy music in the KALLAX shelving unit is primarily caused by the resonance frequencies of the thin particleboard or MDF panels that make up the shelves. Unfortunately, this material thickness is not ideal for absorbing strong vibrations.
A brief overview of my approach:
1. First, I reinforced all the connections at the plug-in joints using the included wood glue to minimize the design-inherent play.
2. Then I lined all shelves—and also the back panel—with thin rubber or neoprene pads at the contact points. These prevent direct wood-on-wood contact, which amplifies the rattling.
3. Additionally, I attached Basotect acoustic foam on the inside of the back panel, which is very effective at reducing vibrations. The foam is fixed in place with spray adhesive.
4. If you have deep bass frequencies, special bass traps or damping mats in the room are also recommended, as the furniture itself can only compensate so much.
I’m also wondering about how the unit is placed: on carpet, hard floor, or is it standing loosely? A stable base (secure footing) can prevent a lot of issues.
If you like, I can provide more precise measurements and sources for the materials. 🙂
O
ODINFLO
7 Jun 2022 14:55
elgla schrieb:
As a first step, I would recommend fastening the back panel firmly and completely
That is a good approach, but especially with KALLAX shelves, the back panel is just a thin fiberboard primarily serving as bracing. It will still transmit vibrations at bass frequencies.
laureo schrieb:
a thin layer of acoustic foam glued behind the back panel
I would be cautious here: acoustic foam absorbs high frequencies well but is hardly effective for low frequencies (bass). To dampen bass vibrations effectively, you need mass or specialized materials like membrane absorbers.
In principle, a thin piece of furniture like the KALLAX offers little effective soundproofing if you can noticeably feel the bass. A tangible improvement would require increasing the structural mass or applying targeted mechanical decoupling of the vibrating parts.
My question to JOFRA9:
What does your setup look like (speakers, volume level)? Is there a way to reduce the bass at the output to relieve the furniture? This approach might require less effort than damping.
JOFRA9
8 Jun 2022 08:32
ODINFLO schrieb:
What does your setup look like (speakers, sound levels)? Is there a way to reduce the bass output to relieve stress on the furniture?
Thanks for the questions!
I’m using a pair of active speakers placed directly on my desk, so quite close to the KALLAX shelf I’m using as a room divider. The bass is relatively strong—not extremely loud, but clearly noticeable.
Reducing the bass on the system itself would be one option, but I don’t want to generally weaken the sound. I’m more interested in a mechanical solution, since I don’t want to replace the shelf.
kibutar schrieb:
1. glued all joints with wood glue
2. lined shelf surfaces at contact points with neoprene pads
3. covered back panel with Basotect acoustic foam
That combination sounds promising.
Are there any alternatives to Basotect that might be more affordable, or do you have experience with how thick the damping layer should be without affecting the shelves?
Also, I’m unsure whether gluing the joints provides a permanent hold or if it reduces flexibility. Has anyone had experience with this?
