ᐅ My Kallax shelf is hardly adjustable anymore after reinforcement – is that normal?
Created on: 3 May 2021 19:22
tulebo
tulebo
3 May 2021 19:22
Hello everyone, some time ago I bought a Kallax shelf unit from Ikea and wanted to reinforce it because it felt quite unstable. I added metal plates and brackets at some of the joints to make the shelf sturdier. This worked well – it’s now much more stable and barely wobbles. However, I noticed that the shelves are now very difficult to adjust in height. Previously, I could easily move the shelves, but now everything feels completely fixed and rigid. This somehow ruins the main advantage of the Kallax for me. Is it normal after reinforcing to have the shelves hard or even impossible to adjust? Or did I perhaps overtighten the screws and basically “fix” the unit? I look forward to your experiences and opinions!
Grace
3 May 2021 20:57
tulebo schrieb:
That the shelves can hardly be adjusted in height anymore...
Hello! The feeling that adjustability decreases after reinforcements is actually quite common. Kallax shelves are originally designed for moderate loads with a lightweight construction principle. If you install metal brackets or plates in a way that they engage directly with the peg holes or side panels, it can significantly reduce the range of movement for the shelves.
Usually, this affects adjustability in that the shelves have less freedom to move because the additional supports hold them in place.
My advice would be to ensure that reinforcements do not permanently deform or fasten the side panels, that the peg holes remain free, and that the option to add extra shelves is still available. If it’s “over-fixed,” it can definitely lead to the shelves no longer being adjustable.
How exactly did you install the metal brackets? Directly on the peg holes or rather on the back panel? Often, it helps if the reinforcement is focused more on the outer sides or the back panel. Hope this helps you for now 🙂
praWarre69
3 May 2021 21:44
Hey tulebo, I totally understand. I once tried to fix up my Kallax and almost gave up when nothing would move anymore. 🙈
tulebo schrieb:
That somehow ruins the main advantage of Kallax for me.
Exactly! Flexibility is basically the core of Kallax. So if you make it super rigid with screws, brackets, and metal, it’s like taking away a chameleon’s ability to change color. 😉
But no worries, you can undo that by using looser brackets or adding reinforcements only at critical points. Sometimes it also helps to install a stronger back panel replacement that stabilizes without blocking the shelf. Maybe a good compromise? Good luck!
rigau
4 May 2021 08:13
tulebo schrieb:
Or did I somehow screw it in too tight and basically "fix" the shelf in place?
If the screws interfere directly with the supports for the shelves, then yes. Mount them more loosely or reinforce the structure in a different way.
FELOTAU
5 May 2021 14:05
The problem sounds very understandable and, to be honest, a bit frustrating when you lose the flexibility of the Kallax shelf.
Grace schrieb:
If you attach metal brackets or plates so that they fit directly into the peg holes or side panels, it can significantly reduce the adjustability of the shelves.
That’s exactly how I know it too. I once installed my reinforcement so that the holes for the shelves were no longer completely free, which also made adjusting them more difficult. What helped me was not tightening the screws fully and slightly shifting the brackets so the shelves weren’t completely blocked.
However, if it has already been screwed in very tightly, it is indeed difficult to fix without disassembly.
praWarre69 schrieb:
But don’t worry, you can reverse this by using looser brackets or only applying targeted reinforcements at critical points.
That sounds like a good compromise. The important thing is to improve stability without completely disabling functionality. Thanks for sharing, it feels better to know you’re not the only one facing this dilemma. 🙂
