ᐅ My KALLAX shelf warped after being exposed to sunlight – what can I do now?
Created on: 14 Nov 2023 08:27
Curtpra
Good morning everyone,
I have a rather specific problem with my KALLAX shelf from IKEA. After being left in the sun on the balcony for a long time, some of the shelves have become warped, which leads me to ask: How can I smooth out or at least repair these warped shelves without having to replace the entire unit?
The shelves are made of laminate-coated fiberboard, and the warping is probably caused by moisture and heat exposure. I am particularly interested in whether heat or moisture worsens the problem and if there are any proven DIY methods to restore the material’s shape.
I would appreciate any tips – how have you dealt with a similar situation or what would you recommend?
KIN42
15 Nov 2023 11:23
One thing that is often underestimated here: the cause usually lies not only in moisture but also in sudden temperature changes.
Material expansion can also permanently damage laminate, so temperature fluctuations should be avoided.
When storing outdoors: protect as much as possible from direct sunlight and moisture, and avoid continuous exposure.
If too much moisture has penetrated the material, complete drying under constant weight is incomparably better than quick methods.
Curtpra
15 Nov 2023 13:50
fredle schrieb:
I still recommend treating the shelves with furniture wax or a similar care product after they have dried
Thanks for the tip, I really wasn’t aware of that. Do you think such a care product is also suitable for laminate coatings, or should I rather use special sealants designed for wood fiberboard?
KIN42 schrieb:
Avoid temperature fluctuations
That’s a good point, too. When the shelf was still assembled, I repeatedly exposed it to very cold nights and warm sunlight. That might have caused the warping.
For now, I will lay the shelves flat, weigh them down, and then see if careful steam ironing can help.
angel
15 Nov 2023 14:29
Curtpra schrieb:
Do you think such a care product is also suitable for laminate coating, or should I rather use special sealants for wood fiberboards?
I recommend not applying regular furniture wax directly on laminate, as it can quickly become streaky or fail to adhere properly. Special laminate care products from hardware stores are better suited and protect against moisture without damaging the surface.
Sealants like hard wax or clear varnish on surfaces not designed for them can alter the appearance. So it’s better to use laminate care products.
