ᐅ My KALLAX shelf is currently being used as a spare parts storage after a flood – how can I clean it?
Created on: 8 Jul 2022 09:12
leoma
Hello everyone, I have a somewhat specific problem: my KALLAX shelf board (which is the IKEA shelf made of particleboard) was used as a temporary spare parts storage after the last flood at my home. Unfortunately, it is now covered with dirt, water stains, and probably some early signs of mold. Since I can’t replace the board immediately, I’m considering how to best clean and restore it properly. Does anyone have experience or tips on how to professionally clean such a KALLAX board (that is, particleboard with a coating) without damaging the material, removing as much mold as possible, and possibly getting rid of odors? What would you recommend to avoid swelling or damaging the surface? Thanks in advance for your help!
rebufar
8 Jul 2022 11:35
SETHBLA schrieb:
Dry first, then wipe with vinegar water.
I understand, but vinegar can dull or damage the coating if it is too concentrated. I think it’s a bit idealistic to treat everything with just vinegar. In my opinion, it’s better to properly wash off the mold first and then seal the area with a special anti-mold spray to achieve a longer-lasting effect.
meGreg
8 Jul 2022 11:59
rebufar schrieb:
In my opinion, it’s better to thoroughly wash off mold and then seal it with a special anti-mold spray.
That sounds almost luxurious 🙂 I assume there aren’t many certified products specifically for wood chipboard. The important thing is that no moisture penetrates the material afterward; otherwise, it’s all pointless.
Kenon70
8 Jul 2022 12:17
Dry, wipe with a slightly damp cloth, remove mold with alcohol. Then allow to dry quickly, otherwise the board will swell.
leoma
8 Jul 2022 17:36
Thanks for the quick responses! Here’s some additional information: The stains on the board cover large areas, and the water was standing for several hours in some places, which is why water marks are visible. The surface has a slight gloss, so there is definitely some kind of coating. I understand that strong cleaners could damage the surface, so it’s better to be cautious. What do you think about mold—should I wear gloves and a mask before cleaning, or is good ventilation enough? Also, how long should a board dry at room temperature before I continue working on it? Thanks again!
edisondan
8 Jul 2022 18:02
In case of mold infestation, wearing gloves and an FFP2 mask is recommended to avoid inhaling spores or transferring them through the skin. Good ventilation is necessary but not sufficient on its own. Drying time depends on humidity and room temperature, typically at least 48-72 hours. The board should no longer feel damp, and surfaces must not be sticky or cold.
Bagupo
9 Jul 2022 09:14
Place in a well-ventilated area, wear gloves, treat mold with 70% isopropanol, and then wipe dry. Dry for at least 2 days, preferably longer.
