ᐅ My Kallax shelf by the window is turning yellow – should I use UV protection?
Created on: 17 May 2022 08:47
Martyn2
Martyn2
17 May 2022 08:47
I have the following issue: My Kallax shelving unit is placed right next to the window, which I actually like because of the natural light. However, I have noticed for some time now that the white Kallax panels are gradually turning yellow, which is likely due to UV exposure. The yellowing bothers me visually, and I am wondering if it would be useful to apply UV protection, such as special films or coatings, to protect the material and prevent discoloration.
Does anyone here have experience with UV protection for IKEA furniture or wooden furniture near windows in general? I am open to advice, including alternatives or other protective measures.
Thanks in advance!
jodeo58
17 May 2022 09:23
UV protection film on the window is the most effective method. Alternatively, regularly treat the shelf with furniture oil or wax, which can provide some protection for the wood.
BOSULE
17 May 2022 11:16
Martyn2 schrieb:
I wonder if it would be useful to use UV protection like special films or coatings to protect the material or prevent discoloration?
That is indeed a reasonable consideration. UV rays cause chemical changes in plastic or paint materials, leading to yellowing. Window films with UV blockers can filter out up to 99% of harmful radiation.
A coating with UV protection is possible, but depending on whether the Kallax finishes are compatible, issues may arise. For example, the surface might change in appearance or texture. From my experience, window protection film is the best option, as it addresses the problem at the source and does not require any additional treatment of the furniture.
Katan
18 May 2022 14:52
Martyn2 schrieb:
My Kallax shelf is right by the window [...] the white Kallax pieces are turning yellowish
Oh, I know that all too well! I also have a “sun worshipper’s corner” with some furniture right by the window, and with certain pieces you can really see that yellowing over time. ;-)
I think the idea of using UV protection film is pretty smart – it not only helps protect your Kallax, but also provides some shielding for the whole room against strong sunlight. Plus, these films come in different tints if you’d like a slightly shaded view.
If you don’t want to apply film on the window, you can also use special furniture lacquers, but depending on the furniture surface, that can be quite tricky. For the Kallax, which is actually melamine coated, it could be difficult because lacquers don’t always stick well or may change the appearance.
So: film = practical & effective, lacquer = effort with no guarantee.
Good luck, and if you go with the film option, let us know how it works out! 🙂
