ᐅ My Kallax unit gets dents quickly from shoes in the hallway – any ideas?
Created on: 29 Aug 2022 08:17
O
Ongau53
I have the following problem with my Kallax shelf, which I use in the hallway as a shoe rack: placing and removing shoes repeatedly causes dents and pressure marks on the surface and the shelves. The unit is made of MDF with a melamine coating, so the surface seems more vulnerable to this kind of damage.
My question: Does anyone have experience or ideas on how to prevent or at least minimize these dents? I want to use the shelf functionally, but the cosmetic damage really bothers me.
Are there any special protective pads, liners, or other solutions that shield the direct contact between the shoes and the shelf without taking up too much space?
I’m grateful for any tips, including mechanical or DIY solutions. Thanks in advance!
O
Ongau53
30 Aug 2022 07:51
blapau schrieb:
A practical solution is thin rubber or felt mats that you place on each floor.
Thanks for the tip, that sounds reasonable. How thin should these mats be at most so that the floors are not too heavily loaded or the storage space is not too restricted?
Vinlen schrieb:
Cork sheets are often available very cheaply at craft stores or home improvement stores and can be cut to size individually
I hadn’t considered cork before. Are there any differences in the processing that I should be aware of? I don’t want the surface to suddenly attract more dirt or reduce the grip of shoes.
FEKAU
30 Aug 2022 09:18
Regarding Ongau53’s question about thickness: Protective coverings between 2 and 5 mm (0.08 and 0.2 inches) are recommended to ensure adequate pressure distribution without causing storage space loss.
On the topic of cork: Make sure the cork boards are sealed or at least surface-treated, as untreated cork can absorb moisture and attract dirt. Sealed cork boards are easy to clean and more cost-effective over time.
In addition to cork and felt, transparent polyurethane materials are also an option if you prefer a nearly invisible solution.
The most important thing is that the shoe sole has no sharp edges or foreign objects that create point pressure – from this perspective, you are already on the right track.
mopra42
30 Aug 2022 12:07
In addition to the base layer, it helps to place shoes with clean and smooth soles. Shoes with hard heel tips or small stones can quickly cause dents.
Additionally, shelf boards can be protected by placing a thin wooden or plastic sheet on top. This provides a stable surface and can be replaced more easily.
taudi
31 Aug 2022 08:46
I am adding a brief guide on how to slightly improve the condition of already damaged MDF surfaces:
1. Thoroughly clean the dents from dust and dirt.
2. Lightly dampen the dent with water without soaking it.
3. Place a damp cloth over the dent.
4. Carefully iron over the cloth with a hot steam iron.
The moisture and heat cause the fibers to swell slightly, making the dent partially rise again. This method is more effective on smooth surfaces than on heavily textured or coated ones. Test it first on an inconspicuous area.
Finally, apply protective film or cork to prevent future damage.
