ᐅ My Kallax only closes properly after several adjustments – what could be the reason?
Created on: 16 Aug 2020 19:43
gautra50Hello everyone,
I recently bought a Kallax shelving unit from Ikea, and during assembly, I noticed that one of the doors does not close properly. More precisely, it jams and often only closes correctly after several adjustments. From my research, I found out that while the hinges can be adjusted, the problem still persists.
I’m wondering what might be causing this: could it be manufacturing tolerances, incorrect installation, warped parts, or perhaps the weight placed on the door?
Has anyone experienced this issue or perhaps has practical tips on how to get the Kallax doors to close smoothly without the need for constant readjustment?
I would appreciate detailed answers or explanations, as I want to get the shelving unit perfect. Thanks in advance!
regarding your issue with the Kallax door: a common cause is often the imprecise alignment of the hinges during assembly. Ikea furniture is designed for mass production, so manufacturing tolerances and material warping can play a role.
An important tip: first, check if the door and the cabinet are lying flat on an even surface. Warped side panels often lead to the door sitting crooked.
Secondly, adjust the hinges not only horizontally but also vertically and in depth. Most Kallax hinge models allow 3D adjustment.
Thirdly, make sure all screws are tight but not over-tightened, as this can warp the hinges.
If the door still sticks despite all adjustments, the door panel might be slightly warped. This can sometimes be corrected by carefully bending it back, but be cautious!
In summary:
- Ensure an even fit by checking flatness
- Adjust hinges precisely in all dimensions
- Check the screws
This addresses the typical sources of the problem.
In summary:
- Check the screws
Hello gautra50,
I can understand how frustrating it can be when a door only closes properly after multiple adjustments. Often, the issue is a combination of several factors, as gaubla has already suggested.
This is really essential. Some people place the Kallax on uneven floors out of habit, which becomes more noticeable due to the thin material than one might expect. One suggestion: also check whether the feet supporting the unit can be adjusted (some models have small leveling screws).
A further tip: make adjustments in small increments and test the movement between each step. Sometimes, a minimal correction is enough to fix the problem. The hinges are designed to allow multi-directional adjustment.
If the door still sticks, check whether any of the sliding surfaces of the door inside the cabinet rub against anything. This can easily cause friction marks that catch when pushing. Lightly sanding the edge along the grain is often sufficient to smooth it out.
I hope this helps you.
gaubla schrieb:
An important tip: First, check whether the door and the cabinet are sitting flat on an even surface.
gaubla schrieb:
Adjust the hinges not only horizontally but also vertically and in depth.
Hello gautra50,
I want to organize my response to help you find a solution more easily. I had a similar issue and resolved it in the following steps:
1. Check the assembly: Carefully tighten all the screws on the hinges without over-tightening. Loose screws are often the cause of wobbling or jamming.
2. Ensure levelness: Position the cabinet so it is truly horizontal and stable. Use a spirit level if available.
3. Adjust the doors: You can adjust the hinges in three directions:
- Horizontal: Moves the door sideways to align it flush with the frame.
- Vertical: Raises or lowers the door so the top and bottom edges are parallel to the cabinet.
- Depth: Controls the distance between the door and the cabinet body.
Take your time to make these adjustments step by step and test the closing movement after each change. The depth adjustment is especially important to prevent the door from hitting something.
4. Check the door leaf for damage: Inspect the edges of the door for slight warping or dents. Sometimes the surface is under tension, which can cause jamming.
5. Material-related refinishing: If the edges of chipboard panels are rubbing, you can remove small burrs with fine sandpaper. This usually makes the door easier to close.
In summary, these steps usually help with your problem. Patience and a systematic approach are key. If it still sticks after that, it might be necessary to replace the door leaf, but this is rarely needed.
Good luck!
Good luck!
