ᐅ My Kallax shelf loses color on the edges every time I clean it – what could be causing this?
Created on: 17 May 2022 09:17
Jonneo66Hello everyone,
I have a somewhat unusual problem with my IKEA Kallax shelf: it noticeably loses color along the edges every time I clean it. I am very careful, using a soft, slightly damp cloth and a mild cleaning agent, avoiding any abrasive products or harsh chemicals. Nevertheless, after each cleaning, small chips or scuffs appear, especially on the edges of the shelves and side panels.
I am curious about what might be causing this. It puzzles me that it happens so quickly, even though I’m handling it gently. Could it be due to the surface coating, the wrong cleaning product, or possibly the manufacturing? I also wonder if this will affect the furniture’s lifespan over time, and how to prevent it without resorting to aggressive sealants or paints.
I look forward to expert opinions and possible solutions!
SauDietmar17 May 2022 10:03Jonneo66 schrieb:
loses noticeable color on the edges with every cleaningThe phenomenon you are describing is common with Kallax and similar shelves made of particleboard with laminate or melamine coating. These pieces of furniture are cost-effective, but the coating on the edges is often less durable than on the flat surfaces.
Basically, this happens for the following reasons:
1. The edges in furniture construction are often covered only with a thin foil or melamine layer, which can be easily damaged mechanically.
2. Moisture can penetrate unprotected or insufficiently sealed edges, causing the surface to soften and leading to chipping.
3. Even light rubbing with a damp cloth or pressing too hard while cleaning can roughen the surface or cause small parts to come off.
My advice:
- Avoid cleaning the edges with excessive moisture whenever possible.
- Use a soft cloth that is only slightly dampened.
- There are also furniture care products with conditioning effects specifically designed for such coatings.
- If you don’t mind, you can lightly seal the edges with clear acrylic or furniture glue to prevent water absorption.
In summary: The issue is less about your cleaning method and more about the surface quality of the edges and their vulnerability to mechanical stress and moisture.
SauDietmar schrieb:
The problem is less about your cleaning method and more about the surface quality of the edgesInteresting point, but I would approach this with a bit more nuance. On one hand, the condition of the edges is certainly crucial, but on the other hand, I wonder if the cleaning method being used should also be questioned.
A "slightly damp cloth" sounds reasonable, but everyone has a different interpretation of that. Even a slight oversaturation of the cloth with cleaning agents can, in the long run, lead to surface deterioration. Additionally, many cleaning products leave residues that can dissolve over time.
I also wonder: Do you use microfiber cloths? Due to their fine fibers, these are known to be gentler than coarse cotton cloths, preventing micro-scratches and minimizing stress on sensitive surfaces.
Without reference measurements and testing, it’s not possible to assign blame here in a general way. It would be interesting to try cleaning without any cleaning agents (just clear water), with different types of cloths, and without wetting the edges to better differentiate cause and effect.
In any case, it should be clear that with chipboard panels that have a foil covering, complete insensitivity to damage is unrealistic.
Jonneo66 schrieb:
it noticeably loses color on the edges of the shelves and side panels with each cleaningTo better understand this, here are a few technical details: IKEA Kallax is usually made from coated particleboard, with the edges sealed using a thin edge banding. This banding is much thinner and less durable than the melamine coating on the flat surfaces.
The peeling on the edges occurs technically because:
- The edge banding is vulnerable to mechanical wear and abrasion.
- Moisture can cause the edge to swell, as the banding is often not fully waterproof and water can penetrate the underlying board.
- Temperature fluctuations can cause the adhesive bond between the banding and particleboard to break down.
You mentioned using mild cleaning agents and a soft cloth, but even minor mechanical stress and moisture cycles can weaken the surface. Cleaning with a slightly damp cloth still transfers water to the edges, which causes damage over time.
One possible countermeasure is to treat the edges afterward with a transparent, flexible edge protection varnish or a special furniture edge sealer. There are acrylic sealants available at hardware stores that are water-repellent and remain flexible, which helps prevent further water damage.
If possible, you could also regularly ventilate the furniture and avoid placing it in damp rooms.
How exactly do you handle the cleaning? Do you use cloths that allow moisture to reach the edges, or is the liquid wiped exclusively from the flat surfaces?
BENBI schrieb:
How exactly do you handle the cleaning process?Thank you for the detailed explanation. When cleaning, I make sure the cloth is only slightly damp and try to wipe the edges gently to avoid moisture penetration. I mostly use microfiber cloths, but sometimes cotton as well.
I was somewhat aware of the edge banding, but I thought it should at least withstand regular cleaning intensity. I will try your tip with the acrylic sealant to see if I can seal the edges with it.
It makes more sense to me now that moisture can cause damage despite careful wiping. There is occasionally higher humidity in my living room since there are also plants.
I will try to be more attentive and reduce the humidity. Thanks also for the suggestion about flexible edge protection; that sounds like a good compromise between protection and preserving the original appearance.
Jonneo66 schrieb:
I will try the tip with the acrylic sealant and see if I can seal the edges with itIn my view, this is the most effective way to permanently solve the problem. Since melamine or edge banding foil on edges is usually not designed for long-term water exposure, a tight, flexible protective layer can significantly improve durability.
Please make sure to use only products that are explicitly suitable for wood or furniture edges. Some universal acrylics can cause unwanted residues or discoloration.
A brief summary:
- Kallax edges consist of thin edge banding foil on particleboard.
- They are susceptible to mechanical abrasion and moisture damage.
- Cleaning with too much water or pressure worsens the condition.
- Sealing the edges with flexible acrylic sealant can significantly extend their lifespan.
Alternatively, purchasing Kallax with solid wood edge strips may be worth considering if a replacement is planned.
