ᐅ My KALLAX shelf has warped significantly after being stored on the balcony – any advice?
Created on: 22 Jan 2022 19:33
emil_baHello everyone,
I stored my KALLAX shelf still in its original packaging on my balcony because I had no space inside. Unfortunately, I have now noticed that the panels warped significantly due to moisture and probably temperature fluctuations. The back panel is bowed, the shelves no longer fit properly, and the whole unit feels somewhat unstable.
Does anyone have experience with whether the wood can be reshaped, or if I will need to replace the entire shelf? Are there any tips on how to salvage a warped piece of furniture like this?
I appreciate your help, as the shelf was actually perfect in size and I would prefer not to have to buy a new one completely.
Oh no, that’s really frustrating! But don’t worry, this can happen when furniture is left on the balcony for too long in changing weather conditions. :-)
First of all: try to acclimate the shelf slowly in a dry, well-ventilated, warm place. Sometimes the board can adjust again this way! If that doesn’t help, you could carefully try using a steam iron – but you have to be very careful with that!
It’s great that you’re looking for a solution – it’s really nice when you can save old furniture! If you have any questions, there are definitely many people here in the forum who know even more tips 🙂
Hello emil_ba,
Your issue with the warped KALLAX shelf after storing it on the balcony can be well explained by the moisture and temperature fluctuations causing the wood to swell. When the panels get wet or damp, the wood often shrinks back in a distorted way as it dries.
Here is a brief guide on how you can address the problem:
1. Drying time: Place the shelf in a dry indoor space with a constant room temperature of 20-22°C (68-72°F) and allow it to dry slowly, but not near radiators or direct sunlight. Drying too quickly often worsens the warping.
2. Corrective measures: If the warping is slight, you can try to straighten the boards using counterweights or clamps. Be cautious when applying force to avoid causing further damage.
3. Check the back panel: The thin back panel greatly stabilizes the unit. If it is severely warped, replacing it (for example, with a chipboard or plywood sheet) can help reduce new warping.
4. Replacing parts: If individual shelves or side panels are already heavily warped, it may be more effective to replace them rather than try to repair.
5. Long-term protection: KALLAX is not designed for outdoor storage. In the future, store furniture indoors or in dry, protected areas whenever possible.
I hope these tips help you!
klo40 schrieb:
Your issue with the warped KALLAX shelf after storing it on the balcony can be easily explained by the moisture and temperature fluctuations...Exactly. Wood expands and contracts, especially with moisture. Bring in dry air, apply clamps, done.
Thanks for the quick and helpful responses so far!
I will definitely try that. Regarding the steam iron: How exactly should it be used without damaging the wood?
I’m also wondering: If the back panel is badly damaged or warped, is there a way to replace it with another material? I read that some people use thin plywood or even metal sheets as reinforcement.
Do you have any recommendations on where to get these cut to size? Thanks in advance!
puvin schrieb:
Try acclimating the shelf slowly in a dry, well-ventilated warm place.
klo40 schrieb:
If it is severely warped, it could be replaced (for example, with an MDF board or a phenolic board)
About steam irons:
The idea is to slightly moisten the wood fibers with steam and restore them to their original shape as they cool. To do this, hold a damp cloth over the warped area and briefly iron over it with the steam iron using light pressure, without soaking the wood. Repeat this process on the affected spots until the deformation is at least partially corrected.
However, be careful: you should test this on an inconspicuous area or a scrap piece of wood first, as it may cause stains or further warping.
Regarding replacement back panels:
Chipboard or thin plywood panels can be cut to size at most hardware stores. Smaller carpentry workshops or wood specialty stores often offer this service at a reasonable price as well. Metal sheets are heavier and require special fasteners but are very sturdy and moisture resistant.
My tip: A 3–4 mm (1/8–5/32 inch) thick birch plywood panel is usually sufficient. Make sure it’s not too thick, as that could unbalance the shelf.
If you have any further questions, feel free to ask!
