ᐅ My KALLAX is standing on a wooden plank floor and wobbles with every step.
Created on: 16 Oct 2020 18:37
RinupraHello everyone,
I recently placed a KALLAX shelf from IKEA in my apartment, standing on a hardwood floor. Unfortunately, the shelf wobbles every time I take a step nearby, which is quite annoying. The floor has a wood finish, is fairly old, and slightly uneven in places, but not extremely warped. I have already tried stabilizing it by putting small pieces of cardboard under the feet, but that barely helped.
Does anyone have experience with making this type of shelf stable on such a floor? Are there special solutions or small accessories that can help stabilize the shelf?
I appreciate any helpful suggestions, thanks!
GUSTAVO5616 Oct 2020 18:52Hello Rinupra,
Your issue with wobbling on floorboards is typical when the floor is uneven or not completely level. The KALLAX shelf stands on four points, all of which bear the load. In such cases, adjustable furniture glides or, in extreme situations, special shims can help.
My suggestion: Measure the height differences at the points where the shelf rests using a spirit level or a ruler. If you know the exact height difference of each foot, you can fine-tune the adjustment with thin self-adhesive plastic pads or felt gliders.
Another option is to use adjustable furniture feet – there are special adapters that can be attached to the underside and then adjusted until the shelf stands firmly.
If the floor is very uneven, using a thin plywood board as a flat base can also provide a long-term solution, which can be fixed in place if needed with non-slip mats.
Question: How old is the floorboard exactly? Are there visible uneven spots, or is the wobbling more minimal?
GUSTAVO56 schrieb:
Question: How old exactly is the wooden plank floor? Are there visible uneven areas, or is the wobbling minimal?The wooden plank floor is probably over 70 years old, made of very stable, solid wood planks. There are visible uneven spots in some places, mainly slight gaps and minor waves. The wobbling is more noticeable when walking close to the shelf, but it’s not a strong tilting movement.
That really sounds annoying. I once had a similar problem with a Billy bookcase on an old wooden floor, and it was really frustrating when it wobbled with every step.
I completely understand that you want to stabilize the shelf without having to move it or carry out complicated modifications. Maybe someone here knows a simple DIY solution that also looks reasonably good.
