ᐅ My KALLAX shelf is developing small chips or rough edges along the corners. Would using wood filler be a good solution?
Created on: 3 Jun 2021 20:17
arjun45
arjun45
3 Jun 2021 20:17
I have an IKEA KALLAX shelf, and for some time now, unattractive small chips have appeared on the outer edges. More precisely, small raised wood splinters or fragments – so-called "noses" – have formed along the edges, which unfortunately affect the overall appearance quite a bit. I suspect this might be due to moisture or mechanical impact, but I am not entirely sure.
Now I am looking for a sustainable solution to either remove or smooth these splinters without compromising the stability or look too much. Are there any recommended products, tools, or methods to properly handle this? I would prefer not to hire a professional workshop and want to tackle it myself.
Perhaps someone here has experience with similar edge damage on the KALLAX or comparable furniture and can offer some advice. Many thanks in advance!
Dopoki
3 Jun 2021 20:46
Hello arjun45,
regarding your issue with the "nips" on the edges of the KALLAX, I can say the following:
These small chip-outs in the wood filler often occur because the chipboard material under the decorative layer is not very resistant to impacts or moisture. As a first step, you should carefully remove the loose wood fibers using fine sandpaper (grit 220 or finer) to prepare the surface for repair.
Afterwards, it is recommended to use a suitable wood filler specifically designed for furniture surfaces – there are special products that can be sanded after drying. Since KALLAX has a melamine-coated surface, it is difficult to repair without the patch being noticeable.
If you want to conceal the damage, you can apply the filler smoothly, let it cure thoroughly, and then smooth it with very fine sandpaper. Finally, I would apply a matching colored paint or wax layer to visually blend the repair.
Be careful not to use coarse tools, as the material can easily chip further.
One more tip: if the "nips" were caused by moisture, you should also address the source to prevent further damage.
I hope this helps.
Tevin
4 Jun 2021 08:53
Hello arjun45,
I fully agree with Dopoki and would like to add a few points to the answer:
Wood filler is a good choice, but it’s important to prepare a smooth and clean surface before applying it. This means you should carefully remove any loose "nibs" first using a sharp utility knife or a small chisel, if they are still loose. Then, sand the area finely so the filler adheres well.
When applying the filler, work as thinly and precisely as possible to avoid an uneven surface later on. After it has dried, be sure to sand the repair smoothly with fine sandpaper, grit 320 or finer.
Since the KALLAX has a smooth surface, I recommend applying a thin layer of clear varnish in matte or satin finish at the end to protect the filler from moisture and further damage.
If you don’t have paint or varnish on hand, many hardware stores offer colored repair kits specifically for furniture, which you can choose to match the KALLAX color.
If you have any further questions about the process, I’m happy to help!
arjun45
4 Jun 2021 10:21
Dopoki schrieb:
These small chips in the wood filler often occur because the particleboard material underneath the decorative layer is not very resistant to impact or moisture.
Thanks, Dopoki, for the clear explanation! You’re right, moisture could indeed be the cause. The shelf is placed in a fairly humid room, and I’ve touched the edges quite often, maybe a bit too roughly.
Tevin schrieb:
The important thing is to create a smooth and clean surface before applying the filler
Removing the loose pieces and gently roughening the surface sounds sensible, so I’ll do that. I also have the appropriate sandpaper and a small utility knife ready.
I’m still unsure which wood filler to use exactly. Are there any recommended brands or products that are especially suitable for engineered wood products with a melamine finish?
I don’t want the color or texture to differ too much after the repair. Thanks in advance for any tips!
mo-hau
5 Jun 2021 14:02
Hello arjun45,
I agree with the previous users and suggestions and would like to add a practical tip:
For repair fillers, I recommend brands like "Pattex 100% Wood Filler" or "Clou Furniture Filler." These are generally designed for touch-ups on furniture, cure to a durable finish, and are easy to sand.
For color matching, it is often useful to use small amounts of colored wood sticks or wax from the hardware store to visually blend the repaired area.
Also, make sure to ventilate well after the repair to allow any remaining moisture in the filler to dry. If your KALLAX shelf is located in a damp room, the problem could occur again.
If possible, you can also attach thin edge protectors made of plastic or metal to the edges. These protect against further damage and prevent the formation of new "noses."
I hope these additional tips are helpful!
Pome60
6 Jun 2021 07:44
Hey arjun45, you can do this! 🙂
Tevin schrieb:
You need to carefully loosen the "noses" first using a sharp utility knife or a small chisel
That’s exactly how I would do it – slow and careful is key here!
KALLAX is really easy to repair if you take your time. If you then use the right filler and sandpaper, you’ll soon have an edge that looks almost like new again. That’s not only pleasing to the eye but also extends the life of your shelf.
I also think mo-hau’s tip about edge protection is great. I did it that way myself, and now the edges look much more durable. Fingers crossed your repair goes well! Let us know soon how it turned out :-)
