ᐅ My KALLAX unit is completely scratched by the vacuum cleaner – what can I do?
Created on: 27 Aug 2021 08:17
nekali
I have the following problem: my Ikea KALLAX shelf is unfortunately quite scratched, mainly caused by my vacuum cleaner. This happens when I run the floor nozzle along it and accidentally scrape against the frame. The scratches are quite noticeable since the surface is mostly white and smooth.
I don’t want to sand everything down because I don’t want to remove the entire finish. Does anyone have tips on how to at least significantly improve or conceal the scratches? Are there any special polishes, waxes, or household remedies you could recommend?
I’d appreciate any help, as I really want to keep the shelf, but the scratches bother me a lot.
SETHBLA
27 Aug 2021 09:02
I have often used the "furniture wax stick" from Edding for such cases. The color is white, and it has helped me well to temporarily make scratches less visible. Easy to use, and Amazon usually has them in stock.
pauPierce
27 Aug 2021 09:10
Be careful when using sandpaper, especially on melamine-coated surfaces. If you sand too aggressively, you’ll wear off the protective layer, making the area more vulnerable to moisture and further damage.
For lightly visible scratches, a combination of wax and polish is often the gentlest solution. It is also important to allow drying time between applications.
Are you fixing the shelf to the floor? Sometimes it helps to attach a small protective strip or edge profile to the bottom edge of the cabinet so that the vacuum cleaner’s floor nozzle does not get too close.
nekali
27 Aug 2021 09:23
pauPierce schrieb:
Are you fixing the shelf to the floor? Sometimes it helps to glue a small protective strip or edge profile to the lower edge of the cabinet
The shelf stands freely on the carpet; it is not fastened. A protective profile is an interesting idea—I honestly hadn’t considered that.
Is it easy to install? And can such a profile be attached just at specific points, for example only where the vacuum cleaner often runs along?
LOJOPAR
27 Aug 2021 09:30
Regarding your question about the protective trim:
Yes, installation is usually very straightforward. You can order small edge or corner protection profiles made of plastic or soft rubber online. These are often self-adhesive and can be cut to length with a utility knife or scissors.
Spot installation is easily possible; the most important thing is that the trim adheres well at the desired spot and that no edges remain loose.
This prevents direct contact between the vacuum cleaner and the surface, significantly extending the lifespan of your shelf.
Alternatively, there are also transparent protective films available if you want to avoid affecting the appearance.
nekali
27 Aug 2021 09:44
Transparent films sound interesting. Are there ones that can be easily cut to size and applied to furniture? Or are they mainly designed for floors?
Has anyone used such a film on melamine-coated furniture and can share long-term experience?
mabla
27 Aug 2021 09:52
I use a transparent protective film (because I have small children). It is easy to cut and also sticks well to smooth melamine-coated surfaces. Durability ranges from several months up to over a year, depending on the level of use.
After removal, there are sometimes sticky residues, but these can be cleaned off with a mild cleaner.
