ᐅ My KALLAX unit has torn at the edges after being heavily loaded – any advice?
Created on: 25 Dec 2024 09:17
saralenHello everyone,
I have a somewhat urgent problem with my IKEA KALLAX shelving unit. After heavy and quite intensive loading, I noticed that the wood veneer surface is actually cracked along some edges. These cracks appear mainly on the outer edges of the shelf components, which makes me a bit concerned since I thought the shelf was designed to handle this kind of load.
The damage not only looks unpleasant, but I’m also worried that the shelf might lose stability over time or deteriorate further. I store books as well as heavy decorative items on the shelf, so maybe that was too much weight.
Has anyone had experience with how to repair or reinforce these cracks? Could protective edge trims be installed somewhere, or maybe the damaged edges treated with a specific varnish or wood adhesive? What is the best way to proceed to prevent further damage and keep the shelf stable?
I would really appreciate your tips, recommendations, or experiences!
saralen schrieb:
After heavy and rather intense loading, I noticed that the wood veneer surface at some edges is actually cracked.This is indeed a common issue with KALLAX shelves, especially when they are used close to their load capacity. The veneer is relatively thin and tends to chip or crack under point pressure or stronger stress.
To help you better, it would be useful to know how heavy the items were and how the load was distributed: for example, were heavy books placed only on one shelf instead of several, or was the weight evenly spread?
What you can definitely do to reinforce the damaged edges:
1. Sand the affected area with fine sandpaper (grit 240 or finer) to smooth rough edges.
2. Apply wood glue or a special repair adhesive for veneer to the cracked spots to stabilize them. Be careful to avoid applying too much glue.
3. Use a clear, matte wood varnish suitable for veneer to seal the area. This will help prevent moisture absorption and further cracking.
4. If the edges are severely damaged, it’s recommended to attach protective strips made of plastic or metal, which you can find as accessories at hardware stores – this significantly increases abrasion resistance.
If you want, I can also send you a list of suitable products that work well for these repairs.
Finally, an important point: KALLAX shelves are rated for a maximum load of about 13 kg (29 lbs) per compartment. So if you’re storing heavier items, try to distribute the weight across several compartments or use reinforcements; otherwise, the material will quickly deteriorate.
Palenar schrieb:
The veneer is relatively thin and tends to chip or crack under point pressure or heavier stress.I know the feeling when you see a beloved, otherwise sturdy piece of furniture suffering. It really frustrated me back then, especially because you want to load the shelf properly.
In your case, I’d first like to encourage you: such damage can definitely be repaired, and most of the time a simple re-treatment can restore a lot of stability. I had a similar situation myself and followed Palenar’s advice.
If I hadn’t waited so long back then, it would have turned out even better. So if possible, start now before the cracks get worse.
Also, if the shelf is heavily loaded in one particular spot, try to reduce the weight there or add reinforcing boards inside. That made the difference for me in the end.
I know it sounds like a lot of work, but it’s worth the effort to preserve the furniture piece in the long run. 🙂
Hello saralen,
I would like to add a small guide on repairing cracked KALLAX edges that might help you:
1. Preparation: First, clean the damaged areas with a dry cloth and remove any loose veneer fibers. This prevents dirt from embedding into the repair.
2. Apply wood glue: Use a high-quality wood glue (PU glue is strong and flexible) and spread a thin layer directly into the cracks. Gently press the edges together if they still open slightly. Immediately wipe off any excess glue with a damp cloth.
3. Clamping: If possible, secure the shelf or at least the damaged compartment with clamps or weights to allow the glue to cure properly. Let it dry for at least 12 hours.
4. After drying: Carefully sand the area with 240-grit sandpaper to remove any unevenness.
5. Sealing: Apply a thin, transparent furniture or wood lacquer (preferably satin finish) to protect the veneer from further wear and moisture.
6. Optional: Suitable edge protectors made of stainless steel or plastic can be installed after lacquering. These help prevent new cracks.
One more tip: If a shelf is under particularly heavy load, you can install an additional support (e.g., a thin MDF board) on the inside to distribute the weight.
I hope this helps! Feel free to ask if you have any questions.
