ᐅ My KALLAX has a completely different shade of white compared to the one I recently purchased – any tips?
Created on: 17 Mar 2021 19:23
Roron42Hello everyone,
I have a KALLAX shelving unit from IKEA at home that I bought about two years ago. Now I wanted to expand it with some additional compartments and recently ordered some extra units. I noticed that the new delivery has a noticeably different shade of white compared to my existing shelving unit. The original has more of a warm white tone, while the new units appear cooler and more bluish.
Does anyone have an explanation for this or perhaps tips on the best way to solve this color issue? Is there a way to match the shades, or would it be better to consider a different solution?
My main concern is a uniform appearance since the shelving is in a living room and the color difference is quite noticeable there.
Thanks in advance for any helpful advice and experiences!
Hello Roron42,
The issue you described with varying shades of white when reordering furniture is well-known and quite common with products manufactured over an extended period. Even if the model is identical, changes in material suppliers, production processes, and color batches often occur subtly.
Please consider the following points:
1. Production batches: Especially with white tones, there can be slight differences that become noticeable when comparing items directly.
2. Lighting effects: Different lighting conditions (e.g., daylight versus artificial light) can make white shades appear differently.
3. Returns/color comparison: Sometimes it is worth comparing the reordered items with other batches if exchanges are possible.
4. Possible solutions: One practical option is repainting with a suitable white paint that matches the original shade.
I recommend asking IKEA directly about batch numbers or stock availability to see if they can supply items from the same batch. Unfortunately, this is not always possible.
I hope these tips help you with your decision.
ladali schrieb:
The issue you described with varying shades of white in furniture reorderings is well-known and often occurs with products that are manufactured over an extended period.I can confirm this, especially with furniture like the KALLAX, where IKEA uses different production sites and material batches. To help you more specifically, here are a few things you should definitely pay attention to:
1. Material properties: The base material can have slightly different surface textures that affect how the color reflects—even if the color itself is consistent.
2. Matte vs. gloss level: Watch out for differences in the finish. A semi-matte finish often appears warmer than a glossy one.
3. Color measurement: If you have access to a colorimeter, you can compare the white values. This helps when choosing the right shade for repainting.
4. As an alternative: You might consider painting individual shelves or elements in a more neutral color, for example, pure white with a slight gray tint—this hides color variations and looks modern.
Finally: It’s best to document every change with photos and try to ask IKEA customer service about the batch number of the new parts—you can sometimes get surprisingly detailed information.
Would you like to share whether your shelving unit has doors or just open compartments? This also influences how noticeable the differences in white tones are.
Roron42 schrieb:
I noticed that the new delivery has a noticeably different shade of white compared to my existing shelving unit.Ah, the classic issue with buying additional pieces of white furniture! I think almost everyone has experienced that. White is never just white – and the difference usually becomes obvious only when you place the items right next to each other.
A little tip: try looking at the different pieces from various angles and under different lighting conditions. Daylight often shows colors differently than artificial light. Sometimes it’s a trick of the eye caused more by lighting than by actual color differences.
If that doesn’t help, applying a suitable coat of paint or finish can really make a difference. I once treated my KALLAX unit with a matte clear lacquer – it brought the surface appearance closer together without being noticeable. Alternatively, you can use matching decorative elements to visually break up the effect.
Otherwise, it’s probably best to stay relaxed and see the shelving as a charming collection. 🙂 Good luck!
