ᐅ My shelving unit gets new stains after every cleaning – how can I prevent this?
Created on: 16 Jan 2021 10:27
KoelreI have a rather unusual problem with my Kallax shelf from IKEA: every time I clean it, new stains appear that weren’t there before. These marks look like water rings or small water spots, but they remain visible even after drying. I usually use a slightly damp cloth and then let it air dry. Obviously, something isn’t quite right – maybe a reaction with the material or a cleaner that leaves residue. Does anyone have any ideas on how to prevent new stains from appearing on the Kallax after each cleaning? I would appreciate concrete tips covering factors such as cleaning methods, suitable products, or the material itself.
Your issue with stains on the Kallax is likely due to a combination of moisture and incomplete drying. Kallax is made from coated particleboard – moisture can sometimes penetrate the surface and cause stains.
My recommendation:
1. Use a cloth that is only slightly dampened with clean water or a mild, pH-neutral cleaner, not too wet.
2. After cleaning, immediately dry the surface thoroughly with a clean, lint-free cloth.
3. Avoid harsh cleaners, as they can damage the coating and promote stain formation.
4. If you use microfiber cloths, make sure they are clean since dirt particles can cause stains.
Following this approach should help prevent stain formation. Stains are not a typical characteristic of Kallax when cleaned properly.
My recommendation:
mo-hau schrieb:
Do not use a too wet cloth; only lightly dampen it with clean water or a mild, pH-neutral cleaning agent.This is the most important point. I would like to add that the cleaning agent used should ideally contain no alcohol or ammonia, as these can damage the surface coating. Additionally, a systematic approach helps:
- First, remove dust by dry wiping. Dust combined with moisture can cause stains.
- For stubborn marks: Use a special wood or furniture cleaner that is compatible with laminate or particleboard.
- It may also help to treat the surface every few months with a dedicated care product for coated furniture to strengthen the protective layer.
It would also be interesting to know exactly what kinds of stains are appearing: Are they glossy, matte, or discolored? This can indicate dirt, water, or chemical reactions. Is the shelf perhaps placed in a specific location where humidity or temperature fluctuations are particularly high?
kulau schrieb:
It would be interesting to know exactly what kind of stains are forming: Are they glossy, matte, or do they have color distortions? They are rather matte, as if the material is slightly "attacked," not glossy. I don’t see any color changes; it appears more like a diffuse discoloration – almost like water stains.
mo-hau schrieb:
Don’t use a too wet cloth, only slightly dampened That about the cloth is correct; I think I sometimes use a bit too much water.
The shelf’s location is quite inconspicuous, in a room with normal temperature and humidity. But since I wipe the shelf frequently (because of a dust allergy), the problem becomes noticeable quickly.
Could it be that normal indoor air or the dust settling encourages the stains? Or should I avoid a specific cleaning agent? Right now, I’m also wondering if I should apply wax or a sealant after cleaning?
Regarding this topic, I can contribute the following: The Kallax is coated with a melamine resin layer, which is very durable but can be sensitive to excessive moisture and inappropriate cleaning agents.
Staining after cleaning is usually caused by the following:
- Residues of cleaning agents on the surface
- Failure to dry thoroughly
- Moisture penetrating the material due to improper cleaning
In response to your question about wax or sealant: This is not necessary, as the melamine resin coating already provides a sealed surface. Wax can even cause shiny or sticky spots.
It is especially important to use only suitable cleaners, meaning no solvents or polishing products. Ideally, use pH-neutral all-purpose cleaners or simply clear water. Avoid applying cleaners directly onto the surface; instead, slightly dampen the cloth.
I can relate well to the descriptions and would like to add some notes on the cleaning method. As already emphasized, controlled use of water is crucial. I’d like to add the following:
- After cleaning with a damp cloth, immediately wipe again with a dry, soft cloth to remove any moisture.
- For stubborn stains, you can use a mixture of water and a few drops of mild dish soap, then thoroughly dry the surface as well.
- Avoid trying to remove stains with harsh chemicals, as this can damage the surface.
- If your Kallax is relatively old, the surface may have small microcracks or abrasions that absorb water. In that case, gentle cleaning is the only option, and replacing the affected parts might be necessary.
I hope this helps. If you like, I can also provide recommendations for detergents or cleaning agents.
