ᐅ My KALLAX unit developed stains after polishing – how can I restore an even finish?
Created on: 15 Oct 2022 19:12
Herschel31
Herschel31
15 Oct 2022 19:12
I recently treated my KALLAX shelf made of oak veneer with a common furniture polish to refresh the wood tone. Unfortunately, instead of a uniform shine, the polish left some spots and uneven dull areas. The transitions now look quite irregular, almost as if I applied different amounts on various surfaces or if the polish didn’t absorb evenly in some places.
My question is: How can I restore my KALLAX to an even finish after such a patchy polishing, without too much effort or having to sand the whole thing down? Are there any special care products, tips, or techniques to reduce the spots and make the appearance more consistent again?
I would appreciate specific advice, especially from people who have had similar experiences with surface-treated wood or more affordable furniture.
Z
zarHenning
15 Oct 2022 19:45
It is best to remove polish residues with a soft, lint-free cloth and some warm water. Afterwards, apply a thin layer of wood oil or wax. This often evens out irregular spots.
bupar
15 Oct 2022 20:03
Stains after polishing often occur due to varying absorbency of the wood, especially with veneers and painted surfaces, like those used in KALLAX.
The first step should be to thoroughly clean the surface with a mild cleaning spray or a damp cloth to remove any excess polish. Afterwards, a uniform follow-up treatment with a suitable care product is recommended, ideally one that closely matches the original condition—such as a product specifically designed for oak-colored veneer.
Mechanical sanding should only be considered as a last resort, as it can damage the veneer.
TARAON
15 Oct 2022 20:17
Oh dear, that sounds really annoying if your KALLAX now looks brushed as if it had been polished with Tinder matches 😉
I would first try gently wiping the surface with a cotton cloth and some thinner, such as denatured alcohol, to break up the uneven greasy film. Be sure to watch the finish carefully during this process to avoid damaging the veneer.
After wiping, immediately follow up with a wood care product, preferably an oil that soaks lightly into the veneer and helps visually even out these stains. It sounds more complicated than it is! 🙂 Sometimes it just takes a little routine to make the shelf shine like new again.
glamo
15 Oct 2022 21:08
@Herschel31 I recently treated my KALLAX shelf with oak veneer using a common furniture polish to refresh the wood tone.
To address the issue properly, it is important to first understand that KALLAX surfaces are usually covered with melamine or a foil overlay on particleboard as the actual surface. This decorative veneer reacts very differently to polish products meant for solid wood. Streaking often occurs because polish residues are not fully absorbed or spread evenly and instead settle on the smooth surface.
As a first step, I recommend gently cleaning the surface with isopropanol or spirits (99%) to remove oily residues. Do not rub too hard – just lightly moisten and wipe carefully to avoid damaging the finish.
Afterwards, it is advisable to apply a thin layer of care wax specifically designed for laminated or veneered surfaces. Resin-free waxes are preferable here, as they create a consistent protective layer that evens out the shine. It is important to distribute it evenly using a microfiber cloth in circular motions to prevent additional streaks.
If that does not help, the only remaining options are professional refinishing or a complete replacement of the fronts, which is rarely practical depending on budget and effort.
Could you please describe more precisely which polish you used? Brand or product details would help to assess the situation.
Herschel31
15 Oct 2022 22:03
Thank you for the quick responses so far! The polish I used was an inexpensive furniture polish from a home improvement store, based on wax and oil, specifically marketed for wood surfaces and furniture. I’m not sure if it’s suitable for veneered or laminated products – but it makes sense that there would be differences.
glamo schrieb:
Polish residues were not fully spread or absorbed and settled on the smooth surface
That matches my impression pretty well. It looks like there are small residues on some surfaces that haven’t been properly absorbed.
I’ll try cleaning it first with a cloth and denatured alcohol, as suggested, and then maybe follow up with a more suitable maintenance wax.
Does anyone have tips on how to approach this thoroughly and carefully so I don’t cause any further damage? I definitely don’t want to harm the veneer—that would be really frustrating.
