ᐅ After cleaning my Kallax with a bleach-based cleaner, the surface became dull and rough – what can I do to fix this?
Created on: 2 Oct 2023 09:46
MeferencHello everyone,
I have a problem with my Ikea Kallax shelf, which now feels quite dull and rough after cleaning it with a common bleach-based cleaner. Previously, the surface was smooth and glossy, but now it seems like there are fine scratches or a matte layer on it that makes the wood veneer look unattractive.
I know that bleach cleaners can be quite harsh, but I only wiped the shelf superficially and did not soak it or anything like that. Does anyone have experience with restoring this dull, slightly rough surface back to its original condition? Are there suitable products or home remedies I could try without making the effect worse?
I would really appreciate your tips and advice – thank you very much!
Hello Meferenc,
I completely understand how frustrating this can be. Especially when you clean carefully and then notice a change like this, it’s really disappointing.
This reminds me a bit of my old bookshelf, where I accidentally used a harsh cleaning product.
My recommendation: don’t try any more chemical treatments until you are sure what has happened to the surface. Sometimes a soft polishing cloth or a special furniture polish pen can help.
Would you like to try gently wiping with a slightly damp microfiber cloth followed by furniture polish to see if the effect improves? If it does, it’s best to continue carefully; otherwise, professional wood care might be necessary.
I’m keeping my fingers crossed that you can fix this!
Meferenc schrieb:
Previously, the surface was smooth and glossy, but now it feels like there are fine scratches or a dull layer on it
Hello Meferenc,
I would like to suggest a structured approach to address the issue of the dull and rough Kallax surface after using chlorine-based cleaner.
1. Understand the cause: Chlorine-containing cleaners can damage the surface of veneered wood or coated panels. They often break down the protective layer or varnish, which leads to the dull, rough surface you’re seeing.
2. Gentle cleaning: First, thoroughly remove all residues with a damp cloth and some mild dish soap. Important: dry well afterward to prevent moisture from causing further damage.
3. Surface treatment: For Kallax, I recommend using a wax-based furniture polish or special furniture care oils to help restore some shine to the coated surface. Use a soft polishing cloth, preferably microfiber, and apply the treatment with circular motions.
4. Alternative: If the surface is heavily damaged and does not respond sufficiently, a very fine abrasive polish (rubbing compound) might help. However, test this very carefully on an inconspicuous area first.
5. Prevention: In the future, avoid using chlorine cleaners or harsh chemicals on furniture.
In summary: gentle cleaning, followed by furniture care products, fine polishing — and please avoid aggressive chemicals.
If you have any further questions, I’m happy to help!
anfeteo schrieb:
Cleaners containing chlorine can damage the surface of veneered wood or coated panels.Thank you for the clear explanation! That’s exactly what I feared—that the cleaner had attacked the protective layer.
Jesus9 schrieb:
Would you like to try wiping it gently with a slightly damp microfiber cloth and then applying furniture polish to see if that reduces the effect?That’s exactly what I will try now. I have a wax-based furniture polish that I once used on my dining table.
I’m curious if it makes sense to lightly go over the surface with very fine sandpaper first (e.g., grit 1000 or finer), or if that would be more harmful than helpful. And if so, how careful does one need to be?
Hello Meferenc,
I’m happy to give you my advice regarding fine sandpaper.
In general, for shelves or furniture with a veneered or lacquered surface like the Kallax, gentle sanding with very fine sandpaper (grit starting from 1000) is only advisable if you want to make small repairs and the damage isn’t too deep.
However, sanding too aggressively can completely remove the finish or highlight imperfections, which will just create more work in the long run. That’s why I recommend testing it first on an inconspicuous spot—perhaps an inside corner that isn’t very visible.
If the shelf just looks dull and rough without significant damage, polishing with furniture wax or wood oil is often sufficient.
My tip: Start by gently wiping the surface with a sponge and some water to remove residues, then apply the polishing cloth or polish. Only sand if that doesn’t have the desired effect and if you’re confident to test on a small area first.
I hope this helps!
Meferenc schrieb:
I’d like to know if it makes sense to carefully sand with very fine sandpaper before polishing
I hope this helps!
To add from a technical perspective:
The surface of the Kallax is usually made of a melamine-coated chipboard, which is relatively resistant but can be damaged by chemicals such as chlorine-based cleaners. The material does not absorb oils, so furniture oil typically does not help here.
I agree with this, but I would like to emphasize that melamine resin-coated surfaces react poorly when exposed to chlorine, and the finish can peel or become cloudy.
Recommended is:
- Gentle cleaning with clear water and a cloth.
- If the surface remains dull, you can gently rub it with very fine abrasive pads (e.g., Scotch-Brite, very fine) using little pressure.
- Afterwards, use a special melamine resin polish suitable for coated furniture.
Sandpaper, especially grit 1000+, might also work depending on how gently it is used, but abrasive pads are better suited because they are less aggressive on the surface.
For the best result, it is advisable to test first on a small area.
Recommended is:
