ᐅ My Kallax surface became dull after cleaning the windows – how can I restore its shine?
Created on: 27 Nov 2022 18:37
KLODIAN65K
KLODIAN6527 Nov 2022 18:37Hello everyone,
I recently cleaned my Kallax shelving unit, which I mainly use for books and decorations, after washing the windows. I wiped the furniture with a damp microfiber cloth and some glass cleaner, thinking it might have picked up some dust or fingerprints. Unfortunately, I later noticed that the surface became quite dull and matte, almost as if a fine haze had formed.
My question is: Is there a way to restore such a dull surface on the Kallax shelf after cleaning, or at least bring back its original matte to slightly glossy appearance? What products or methods are suitable for the coated wood-based material surface without causing damage? I want to avoid coarse sanding or harsh cleaners since I don’t want to harm the furniture.
I would really appreciate any helpful tips on how to refurbish a dull furniture surface like this.
Hello KLODIAN65,
Based on your description, it is very likely a so-called "water or cleaner film" that is making the surface of the Kallax furniture look dull. This can result from the combination of glass cleaner and the coated surface. Many glass cleaners contain alcohol or ammonia, which can slightly damage the sealant.
My advice: Use a slightly damp cloth with lukewarm water and a little dish soap to remove the film as completely as possible. Afterward, you should thoroughly dry the surface with a clean, dry microfiber cloth.
If the surface remains dull, you can try applying a small amount of furniture oil or wax specifically designed for coated surfaces. It is best to choose a product suitable for laminate or MDF surfaces, as the Kallax has a melamine resin-coated panel.
Please avoid using strong abrasive cleaners or sanding materials, as this could damage the surface.
For future cleaning, I also recommend avoiding glass cleaners and instead using mild cleaning agents to protect the surface.
Hello KLODIAN65,
I would like to add to pikin’s explanations and go into a bit more detail, as the surfaces of Kallax furniture are usually coated with melamine, which can be sensitive to chemical agents.
When you mention a “dulling” effect after cleaning the windows, it is likely that residues of the cleaner or its ingredients (e.g., ammonia, alcohol, surfactants) have been trapped, causing the surface to appear cloudy. Such films can also result from micro-corrosion of the surface sealant.
The following process may help:
1. Clean the surface again with a soft cloth lightly dampened with water and a small amount of dish detergent to remove any cleaner residues. Avoid using large amounts of liquid.
2. Immediately dry the area with a lint-free cloth to prevent water spots.
3. Use a care product suited for melamine surfaces. Specialized furniture care products or maintenance oils for plastic or laminate surfaces work well. These often contain polymers that refresh the surface and restore gloss.
4. Apply the care product sparingly and spread it thinly and evenly with a soft cloth. Avoid thick layers.
Since you don’t want to damage the furniture, abrasion or sanding is not recommended. If the effect does not improve after treatment, the protective surface layer may have been permanently affected. In that case, gradually replacing the surface or professional refinishing might be necessary, although this is uncommon for Kallax furniture.
I’m curious which glass cleaner exactly was used and how long the surface remained wet after cleaning—details like these can influence the cause more precisely.
KLODIAN65 schrieb:
Is there a way to restore a dull surface of the Kallax shelf after cleaning, or at least bring back its original matte to slightly glossy appearance?Use lukewarm water with mild dish soap, then dry thoroughly. If the surface remains dull, apply laminate furniture oil sparingly, let it sit briefly, and then polish.
Do not sand or use aggressive cleaners.
