ᐅ My IKEA Platsa shelving unit is tipping over – do you have any solutions?
Created on: 8 May 2024 18:37
lejonte
I have a problem with my IKEA Platsa shelving unit that I assembled just a few weeks ago. Unfortunately, the unit tends to tip forward slightly, even though I have anchored it to the wall. It consists of several modules combined (width 180cm (71 inches), height 192cm (76 inches)) that should be stable according to the instructions. The anchoring is in place, but the top section sometimes wobbles, especially when I open a door or place heavier items on top.
I’m wondering if I’m overlooking something—such as missing special brackets, additional fasteners, or other tips to make the shelving more secure and stable? Has anyone experienced something similar or found solutions?
I look forward to any helpful advice!
Luciandi
10 May 2024 09:38
I can definitely understand how annoying a wobbly shelf can be, especially when you’ve put effort into assembling it neatly.
lejonte schrieb:
The floor is indeed slightly uneven, I hadn’t considered that yet.
Uneven floors sound like the key issue here. I would try placing small wooden or rubber wedges under the bottom feet to level the shelf. They are usually inexpensive and discreet when used correctly.
Also, I recently learned how important the correct assembly sequence is. If the modules aren’t properly connected or a part is only loosely fitted, it can increase the wobbling effect.
Don’t get discouraged! With a few small adjustments, you should be able to stabilize the shelf. And if you have any questions, feel free to reach out again. Good luck!
