ᐅ Installation of Decentralized Blauberg Ventilators – Which Expanding Foam to Use?
Created on: 28 Jan 2018 18:02
krischaaan
krischaaan
28 Jan 2018 18:02
We will soon be installing our decentralized ventilation system. We chose the Blauberg Vento fans because of their excellent heat recovery efficiency...
Which mounting foam should be used to seal between the drilled hole and the fan? Is there a particularly insulating type?
Thank you very much for your answers.
Good luck. Christian
Baumfachmann
28 Jan 2018 19:24
Soudal Energy Construction Foam B2 Genius Gun 500 ml (16.9 fl oz) at OBI, Toom
HIGIL17 Mar 2018 09:23
It is important to use a non-expanding two-component foam here. These foams are also used for installing windows and doors.
