ᐅ Installing a Wall-Mounted Shelf – Metal Everywhere Inside the Wall?
Created on: 27 Feb 2018 08:40
bpe87Good day,
I need your advice once again.
I want to hang a wall shelf. I bought a Bosch multi-detector, which shows metal/pipes/cables (indicated by yellow/red lights on the detector) in at least 50% of the wall area and especially in the spot where I plan to mount the shelf. So, there is some kind of metal inside the wall. The wall separates the living room from the bathroom (bathtub and washing machine connection), and there is another apartment above us. The shelf is supposed to be mounted at about 1.70m (5 ft 7 in) height. There are several power outlets in the lower part of the wall, but based on my research online, I assume the cables probably run downwards toward the floor.
The landlord unfortunately does not have any building plans. Should I just drop this idea? Or would it be better to consult a professional? What would you do?
bpe
bpe
