ᐅ How to Securely and Neatly Install Ikea Metod Kickboards with Underfloor Heating
Created on: 15 Feb 2023 08:34
Jan36
I am planning to install the Ikea Metod system with baseboards directly over an underfloor heating system in my kitchen. I have a few questions regarding safe and proper installation, especially since the baseboards will be in contact with the usually sensitive underfloor heating.
- How can I prevent the baseboards from being damaged by heat or moisture?
- Are there specific fastening methods or spacing requirements I should follow?
- Do I need to use special materials (e.g., seals, adhesives, profiles) to accommodate expansion and thermal movement?
- How can I achieve a clean and even appearance without negatively affecting the heating performance?
I would be very grateful for any practical experience, tips, or expert advice. Thank you in advance!
lajudo
15 Feb 2023 12:04
The distance to the underfloor heating should be at least 8 mm (0.3 inches). Install clips loosely, do not glue.
Expansion joints should be at least 2 mm (0.08 inches) wide and sealed with white silicone.
glapu
15 Feb 2023 12:35
Do not install baseboards directly on the floor. Ensure ventilation. Leave expansion joints open at corner connections and use flexible adhesive.
Jan36
16 Feb 2023 08:15
Following your recommendations, I have separated the baseboards from direct contact with the floor using small wooden wedges. At the corners, I left 2 mm (0.08 inches) gaps and filled them with flexible silicone.
Now I am wondering if I should additionally protect the baseboards from impact or damage caused by furniture, since the gap is somewhat larger. Are there any suitable solutions available that blend in aesthetically?
I am also interested to know if the ventilation created by the gap significantly affects the heating performance of the underfloor heating, especially during winter.
daalessio
16 Feb 2023 10:45
To protect the baseboard from impacts, a transparent plastic edge guard strip is suitable. It is easy to install and hardly noticeable visually. Alternatively, you can use protective profiles made of aluminum if you prefer a more durable option.
For ventilation: A gap of 8-10 mm (0.3-0.4 inches) mainly helps improve heat emission into the room. Warm air can circulate without becoming trapped under the baseboard. This means the heating performance is not negatively affected; on the contrary, air movement supports heat distribution.
The most important factors for your underfloor heating remain proper installation, insulation beneath the screed, and temperature control.
toril
16 Feb 2023 11:02
A floor heating system works best when the surface temperature remains consistent. Baseboards with a gap improve air circulation.
Edge protection is optional and helps with mechanical durability. Plastic profiles can be customized visually, while aluminum profiles are much more robust but more noticeable.
Heat loss through ventilation is minimal and should be considered according to the technical data of the heating circuits.
Jan36
16 Feb 2023 12:43
daalessio schrieb:
The gap of 8-10 mm (0.3-0.4 inches) rather helps to improve heat emission into the room.
That reassures me a lot. I didn’t want the whole setup to reduce efficiency.
What are your thoughts on cleaning the baseboards with this gap? Does a lot of dirt tend to collect underneath? Should you vacuum under them, or do flexible mounting systems allow this without any issues?
